This happened after a router restart.
I noticed the issue when I ssh'ed to my homelab server.
The custom welcome script hangs on:
`hostname -I | /usr/bin/cut -d " " -f 1` and `wget -q -O - http://icanhazip.com/ | tail`
It used to output a ipv4 and ipv6 address. Now just the internal and external ipv4 after a timeout (from the ipv6 resolving i guess).
The /etc/resolv.conf had the exact timestamp of the router restart, so I was focusing on this config. I feel like I'm missing my router's IP on the first line.
Commands (I killed commands after 2 minutes without response):
nslookup
kevin@raspberrypi:~ $ nslookup www.google.com
Server:         1.1.1.1
Address:        1.1.1.1#53
Non-authoritative answer: Name: www.google.com Address: 172.253.120.106 Name: www.google.com Address: 172.253.120.105 Name: www.google.com Address: 172.253.120.104 Name: www.google.com Address: 172.253.120.147 Name: www.google.com Address: 172.253.120.103 Name: www.google.com Address: 172.253.120.99 Name: www.google.com Address: 2a00:1450:400c:c01::6a Name: www.google.com Address: 2a00:1450:400c:c01::67 Name: www.google.com Address: 2a00:1450:400c:c01::69 Name: www.google.com Address: 2a00:1450:400c:c01::68
ping
kevin@raspberrypi:~ $ ping www.google.com
PING www.google.com(wj-in-x67.1e100.net (2a00:1450:400c:c01::67)) 56 data bytes
^C
--- www.google.com ping statistics ---
367 packets transmitted, 0 received, 100% packet loss, time 374791ms
kevin@raspberrypi:~ $ ping 2a00:1450:400c:c01::67 PING 2a00:1450:400c:c01::67(2a00:1450:400c:c01::67) 56 data bytes ^C --- 2a00:1450:400c:c01::67 ping statistics --- 13 packets transmitted, 0 received, 100% packet loss, time 12284ms
kevin@raspberrypi:~ $ ping 172.253.120.106 PING 172.253.120.106 (172.253.120.106) 56(84) bytes of data. 64 bytes from 172.253.120.106: icmp_seq=1 ttl=57 time=23.5 ms 64 bytes from 172.253.120.106: icmp_seq=2 ttl=57 time=18.8 ms 64 bytes from 172.253.120.106: icmp_seq=3 ttl=57 time=18.6 ms 64 bytes from 172.253.120.106: icmp_seq=4 ttl=57 time=18.6 ms 64 bytes from 172.253.120.106: icmp_seq=5 ttl=57 time=18.4 ms 64 bytes from 172.253.120.106: icmp_seq=6 ttl=57 time=18.6 ms ^C --- 172.253.120.106 ping statistics --- 6 packets transmitted, 6 received, 0% packet loss, time 5009ms rtt min/avg/max/mdev = 18.357/19.426/23.534/1.841 ms
traceroute
kevin@raspberrypi:~ $ traceroute www.google.com
traceroute to www.google.com (172.253.120.105), 30 hops max, 60 byte packets
 1  192.168.0.1 (192.168.0.1)  1.599 ms  1.696 ms  1.754 ms
 2  * * *
 3  * * *
 4  * * *
 5  * * *
 6  * * *
 7  * * *
 8  108.170.241.225 (108.170.241.225)  30.000 ms 142.251.255.38 (142.251.255.38)  24.602 ms 142.250.224.130 (142.250.224.130)  24.438 ms
 9  108.170.241.141 (108.170.241.141)  29.613 ms 108.170.241.205 (108.170.241.205)  29.620 ms 108.170.241.237 (108.170.241.237)  29.355 ms
10  216.239.42.213 (216.239.42.213)  29.938 ms 216.239.41.49 (216.239.41.49)  29.745 ms  29.528 ms
11  142.250.227.197 (142.250.227.197)  30.911 ms  30.768 ms 216.239.43.129 (216.239.43.129)  24.435 ms
12  64.233.175.102 (64.233.175.102)  29.005 ms 142.251.69.115 (142.251.69.115)  30.636 ms *
13  172.253.67.149 (172.253.67.149)  24.060 ms * 172.253.67.145 (172.253.67.145)  86.527 ms
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  wd-in-f105.1e100.net (172.253.120.105)  22.514 ms  29.539 ms  27.640 ms
/etc/hosts
kevin@raspberrypi:~ $ cat /etc/hosts
127.0.0.1       localhost
::1             localhost ip6-localhost ip6-loopback
ff02::1         ip6-allnodes
ff02::2         ip6-allrouters
127.0.1.1 raspberrypi
/etc/resolv.conf
kevin@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
search telenet.be
nameserver 1.1.1.1
nameserver 8.8.8.8
nameserver 2a02:1800:100::44:1
nameserver 2a02:1800:100::44:2
/etc/dhcpcd.conf
kevin@raspberrypi:~ $ cat /etc/dhcpcd.conf
# A sample configuration for dhcpcd.
# I removed all the comments for this post.
hostname
clientid
persistent
option rapid_commit
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
option interface_mtu
require dhcp_server_identifier
slaac private
I edited this during setup but still does the job:
interface eth0 static ip_address=192.168.0.10/24 static routers=192.168.0.1 static domain_name_servers=1.1.1.1 8.8.8.8
/etc/os-release
kevin@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
traceroute6
kevin@raspberrypi:~ $ traceroute6 www.google.com
traceroute to www.google.com (2a00:1450:400c:c01::63), 30 hops max, 80 byte packets
 1  ptr-ufkks9jjer3gq79p1p.18120a2.ip6.access.telenet.be (2a02:1810:1c2c:6c00:6802:b8ff:febd:b60d)  5.232 ms  5.176 ms  5.116 ms
 2  * * *
 3  * * *
 4  * * *
 5  * * *
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
