I'm on RPI 4. I'm trying to install the RPIO module to control an ESC. When I type in the command sudo python setup.py install I get the error ImportError: No module named setuptools. When I install setuptools using the command sudo apt-get install python3-pip it prints out 0 upgraded, 0 newly installed, 0 to remove and 31 not upgraded. and when I try using the command sudo python setup.py install I get the same error even though I downloaded setuptools (for some reason nothing was changed or updated)
EDIT: I've tried installing this way (1st answer) but when I type in the command unzip RPIO-2.zip I getunzip: cannot find or open RPIO-2.zip, RPIO-2.zip.zip or RPIO-2.zip.ZIP.
