I have a CM4 Compute Module and am trying to set the clock phase on the second SPI channel. But the ioctl() to set mode returns an error whenever I attempt to set this phase bit:
int fd = open("/dev/spidev1.0", O_RDWR);
unsigned int mode;
mode = 0; // normal clock phase ioctl(fd, SPI_IOC_WR_MODE, &mode); // this works
mode = 1; // inverted clock phase ioctl(fd, SPI_IOC_WR_MODE, &mode); // this fails!
I have tried the test program spidev_test.c and it has the same problem. The program errors when adding the flag to set the clock phase:
./spidev_test -D /dev/spidev1.0 --cpha
can't set spi mode: Invalid argument
Aborted
./spidev_test -D /dev/spidev1.0 spi mode: 4 bits per word: 8 max speed: 500000 Hz (500 KHz) (data follows, i.e. this works)
Is there some reason that clock phase can't be set on spidev1.0? Setting the phase does work on spidev0.0.
Here is my kernel version: Linux raspberrypi 5.19.0-rc1-v8 #1 SMP PREEMPT Tue Jun 7 21:32:27 UTC 2022 aarch64 GNU/Linux
Can anyone else with a CM4 verify this behavior? The instructions for downloading and building the spidev-test program can be found here: https://github.com/raspberrypi/documentation/blob/develop/documentation/asciidoc/computers/raspberry-pi/spi-bus-on-raspberry-pi.adoc
Jon
  • 121
The Pi's auxiliary SPI only supports modes 0 and 2.
See http://abyz.me.uk/rpi/pigpio/cif.html#spiOpen
This was discovered by experiment.
joan
  • 71,852
  • 76
  • 108
In short, I have determined that joan is correct in saying that the hardware cannot support modes 1 and 3. More detail follows.
I investigated why only modes 0 and 2 are supported in the driver. The code in question is in https://github.com/raspberrypi/linux/blob/rpi-5.15.y/drivers/spi/spi-bcm2835aux.c. The chip's datasheet https://datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf indicates it has some bits to support the other clock phase. I modified the driver to allow SPI_CPHA to control these bits: "In Rising" and "Out Rising". I built the kernel and tested this out in sending SPI to a serial EPROM. Changing the "Out Rising" bit to 0 has the desired effect of making the data change on the falling edge. But it has an undesired effect sending the data out one clock too soon, essentially shifting the data left by one bit. So the first bit you try to send gets lost and there is an extra 0 bit at the end of the last word. I played around with shifting the data, but it was really feasible. In the end, I solved the problem a different way.
Jon
  • 121
