The title says it all. The current version of Pop!_OS for the Pi 4 does not offer the option to encrypt the root partition.
What follows is basically this answer adapted to the current Pop!_OS release, with additional tweaks. This took me almost a day of tinkering and testing until everything worked flawlessly with the fewest possible changes to the original image.
Download Pop!_OS for the Raspberry Pi 4. You should now have a file pop-os_22.04_arm64_raspi_3.img.xz or similar.
Take a fast USB stick or an SSD and connect it to a USB port of your Linux desktop PC (I'm going to assume a Gnome desktop). If partitions mounted automatically, unmount them (easiest via the Disks application) but make sure the drive still appears in Disks. Going forward the instructions will assume this is /dev/sda.
Create a text file named install somewhere and open it in an editor.
Add the following script:
#!/bin/bash # Adapt the following variables to suit image=~/Downloads/pop-os_22.04_arm64_raspi_3.img.xz drive=/dev/sda device=/dev/sda2 partitionNumber=2sudo xzcat $image | sudo dd of=$drive status=progress sudo e2fsck -f $device
Resize the filesystem to minimal size to make room for LUKS header
sudo resize2fs -p -M $device
Encrypt in place
sudo cryptsetup-reencrypt --new --reduce-device-size 64M --type=luks2 --cipher xchacha12,aes-adiantum-plain64 --key-size 256 --hash sha512 --use-urandom $device
Resize partition to maximum. NOTE: growpart probably needs to be installed
sudo growpart $drive $partitionNumber sudo cryptsetup luksOpen $device writable sudo e2fsck -f /dev/mapper/writable
Resize filesystem to fill the partition
sudo resize2fs -p /dev/mapper/writable
Adapt the variables at the top to suit your situation. The
imagevariable will almost certainly be different. The other variables are often correct for USB sticks and SSDs connected over USB.Save and close the editor.
Open a Terminal in the folder where you created the install file.
sudo chmod a+x install./installThis will take a few minutes (even with a fast SSD). Along the way you will be prompted for your password and the encryption passphrase a few times.
When the script is finished, mount both the system-boot and writable partitions manually. On a system with a GUI, this is most conveniently done by powering down (e.g. in Disks), removing and replugging the device). You will need to enter the encryption passphrase.
Back in the terminal enter
sudo gedit(or use your favorite editor instead). Thesudoensures that we can edit files in the writable partition.In the writable partition open /etc/crypttab and replace the example line with the following line:
writable /dev/sda2 none luksNOTE: Apparently, the elements must be separated by TABS and there must be a LF at the end.
In the writable partition open /etc/fstab and change the first line as follows (
noatimeonly, the rest should be similar):LABEL=writable / ext4 defaults,noatime 0 0In the system-boot partition open cmdline.txt and change it as follows (
usb-storage.quirksandcryptdeviceneeds to be added; if present,splashmust be removed):usb-storage.quirks=aaaa:bbbb:u dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc cryptdevice=/dev/sda2:writableNOTE: The
usb-storage.quirksentry is only necessary for some USB adapter-->SSD combinations. Without it, you will get abysmal read/write performance. If so, you should find the id of your SSD withlsusband replaceaaaa:bbbbwith the id of your SSD.Save all files and close the editor.
Unmount all partitions, power down the device (if necessary) and connect it to your Raspberry Pi 4. Initial boot will take a long time (>5 minutes). At times the boot process will appear to be stuck only to resume after a minute or two. It is expetced to finally fail and display an
(initramfs)prompt.At the
(initramfs)prompt, entercryptsetup luksOpen /dev/sda2 writable.At the
(initramfs)prompt, enterexit. The boot process will now resume and boot into Pop!_OS.After going through initial setup, open a Terminal and enter
sudo update-initramfs -u.sudo reboot. After a few seconds, the system should ask you for the encryption passphrase and then quickly boot to the login screen.
- 21
- 3
