I use an under-clocked Rasberry Pi 4 to save power using these settings in /boot/config.txt:
arm_freq=700
arm_freq_min=100
core_freq=250
core_freq_min=75
sdram_freq=400
over_voltage=0
# source
# https://www.foxplex.com/sites/raspberry-pi-over-und-underclocking/
and only 1 cpu (maxcpus=1 in /boot/cmdline.txt). Unfortunately, the shell command sleep 10 (and the equivalent commands in Python or Julia) now waits 43 seconds instead of 10. Any ideas how this can be corrected?
When the CPU is under-clocked I get these timings (as suggested by @Seamus):
pi@drifter02:~ $ date +%M:%S:%N; sleep 10.; date +%M:%S:%N
42:18:636998788
43:21:810109674
43:24:804538802
43:34:815360222
43:36:331290110
43:46:341481104
43:49:616077991
44:54:628062596
Even if the the two timestamps of date report 10 s (2nd and 3rd test), it does not correspond to what I see with a stop watch. Or using the time command over ssh, I get more consistent timings (but consistently wrong)
$ date +%M:%S:%N; ssh  pi@192.168.0.199 sleep 10.; date +%M:%S:%N;
50:07:581271832
50:34:179524391
50:35:132595217
51:07:345482960
51:08:313846466
51:36:433839692
52:03:028000964
52:37:534952569
Just executing pwd takes about 0.5 s, so the time it take to make a SSH connection cannot be blamed.
$ date +%M:%S:%N; ssh  pi@192.168.0.199 pwd; date +%M:%S:%N;
54:03:634693731
/home/pi
54:04:184457211
Without under-clocking, the timings are correct.
More infos:
  • Raspberry Pi 4 Model B Rev 1.5
  • Linux 5.15.61-v8+, aarch64
  • Debian GNU/Linux 11 (OS reported in /etc/issue)
  • Installation image: Rapberry Pi OS Lite (64-bit)
Alex338207
  • 119
The issue is the option arm_freq_min=100. Apparently, lowering this frequency is not supported (and not reducing significantly the power consumption anyways):
Minimum value of arm_freq used for dynamic frequency clocking. Note that reducing this value below the default does not result in any significant power savings and is not currently supported.
https://www.raspberrypi.com/documentation/computers/config_txt.html
Alex338207
  • 119
