I have been playing with my newly acquired Raspberry Pi Pico W and reading the temperature.
How much variation between the internal temperature sensor and an external TMP36 wired up to ADC2 should I be expecting?
The value from the internal sensor seem to be lower than the external one, where I would expect it to be the other way around.
Code for reading internal sensor
import machine
import utime
class GetTemp: """Read the internal temp sensor"""
def __init__(self):
    """Init"""
    self.sensor_temp = machine.ADC(4)
    self.convert = 3.3 / 65535
    self.temperature = 0
def get_temp(self):
    """Read the Internal Temp Sensor"""
    reading = self.sensor_temp.read_u16() * self.convert
    self.temperature = 27 - (reading - 0.706) / 0.001721
    return self.temperature
def get_temp_f(self):
    """Get Temp in Fahrenheit"""
    return (self.get_temp() * 1.8) + 32
if name == "main": temp = GetTemp() while True: print("%.4f C, %.4f F" % (temp.get_temp(), temp.get_temp_f())) utime.sleep(1)
Code for reading the TMP36 sensor
import machine
import utime
class GetTemp: """Read the temp from a TMP36 sensor"""
def __init__(self, adc, ref_voltage=3.3):
    """Init"""
    self.sensor_temp = machine.ADC(adc)
    self.convert = ref_voltage * 1000 / 65535
def get_temp(self):
    millivolts = self.get_raw() * self.convert
    self.temperature = (millivolts - 550) / 10
def get_raw(self):
    return self.sensor_temp.read_u16()
if name == "main": temp = GetTemp(2) while True: print("%.4f C, %.4f F" % (temp.get_temp(), temp.get_temp_f())) utime.sleep(1)
Example Output
TMP36 = 15.6729 C, Internal = 16.2771 C
TMP36 = 15.5924 C, Internal = 15.8089 C
TMP36 = 15.7535 C, Internal = 15.8089 C
TMP36 = 15.6729 C, Internal = 15.8089 C
TMP36 = 15.7535 C, Internal = 16.2771 C
TMP36 = 15.5924 C, Internal = 16.2771 C
Is there anything else I can check or troubleshoot with the TMP36 sensor to make it more accurate?
You don't give any output, but I notice your code (which I haven't analysed in detail) gives slightly different results to mine (on Pico).
23.29925
24.2355 C, 74.7813 F
from machine import ADC
import utime
sensor_temp = ADC(ADC.CORE_TEMP)
conversion_factor = 3.3 / (65535)
while True:
    reading = sensor_temp.read_u16() * conversion_factor
    temperature = 27 - (reading - 0.706)/0.001721
    print(temperature)
    utime.sleep(2)
I believe this may be because ADC is expecting a pin not an integer. I had encountered a similar issue reading VSYS. See https://forums.raspberrypi.com/viewtopic.php?p=1809725#p1809725
