I'm trying to setup an automated backup system to backup my Raspberry Pi's data to my Mac Mini. However, calling neither borg init nor borg create from the RPi to the remote Mac Mini repo host seems to reach the borg server running on the Mac Mini. On the Mac Mini:
% sudo borg serve --debug --restrict-to-path /Users/borg/BorgRepos/RetroPie
$LOG DEBUG borg.logger Remote: using builtin fallback logging configuration
$LOG DEBUG borg.archiver Remote: 33 self tests completed in 0.12 seconds
On the RPi:
$ sudo borg create --debug --stats borg@octolen:/Users/borg/BorgRepos/RetroPie2::Friday2 RetroPie
35 self tests completed in 0.59 seconds
SSH command line: ['ssh', 'borg@octolen', 'borg', 'serve', '--umask=077', '--debug']
Password:
Remote: zsh:1: command not found: borg
Connection closed by remote host. Is borg working on the server?
File "/usr/lib/python3/dist-packages/borg/archiver.py", line 4455, in main
exit_code = archiver.run(args)
File "/usr/lib/python3/dist-packages/borg/archiver.py", line 4387, in run
return set_ec(func(args))
File "/usr/lib/python3/dist-packages/borg/archiver.py", line 134, in wrapper
make_parent_dirs=make_parent_dirs, args=args)
File "/usr/lib/python3/dist-packages/borg/remote.py", line 577, in __init__
raise ConnectionClosedWithHint('Is borg working on the server?') from None
borg.remote.ConnectionClosedWithHint: Connection closed by remote host. Is borg working on the server?
Platform: Linux retropie2 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
Linux: debian 10.13
Borg: 1.1.9 Python: CPython 3.7.3
PID: 28539 CWD: /home/pi
sys.argv: ['/usr/bin/borg', 'create', '--debug', '--stats', 'borg@octolen:/Users/borg/BorgRepos/RetroPie2::Friday2', 'RetroPie']
SSH_ORIGINAL_COMMAND: None
I did add /usr/bin/borg to the Mac's firewall's list of applications permitted to allow incoming connections. What am I missing here?
