Referring to the Task Bar of pi's GUI (not the top of open application windows but the screen's task bar), I would like to display a permanent text label so I know which of many boot disks I'm using.
My task bar currently contains application icons on the left, and clock, connections, and audio icons on the right. I know how to add and delete items from the options but am wondering if there is a way to display a text label in the task bar.
I found the same question on another forum https://forums.raspberrypi.com/viewtopic.php?p=1326603#p1326603 but no useful answer there and the topic is now locked.
I have a laborious alternative where I manually edit an image to add the label and use the image as desktop wallpaper but it is often hidden by open windows and I would prefer it to be in the task bar.
Any ideas of how to achieve this gratefully received (pi400, Raspberry Pi OS 32 bit).
update
After some exploration I have found a config file here:
~/.config/lxpanel/LXDE-pi/panels/panel
That begins:
# lxpanel <profile> config file. Manually editing is not recommended.
# Use preference dialog in lxpanel to adjust config when you can.
and contains an entry that might be where I could add something:
Plugin {
  type=taskbar
  expand=1
  Config {
    tooltips=1
    IconsOnly=0
    ShowAllDesks=0
    UseMouseWheel=1
    UseUrgencyHint=1
    FlatButton=0
    MaxTaskWidth=200
    spacing=1
    GroupedTasks=0
Has anyone edited this file or knows what properties are available for setting?
AFAIK there is no existing code to "display a permanent text label" although you can kludge by just changing the name of an existing plugin.
I have written a plugin to display hostname and it would be simple to modify to display an arbitrary string.
