I am trying to use a RAM disk on a Pi 4, 4GB, to speed up processing and avoid writing a lot to the SD card. But somehow my application fills up the RAM disk until a java.io.IOException: No space left on device is hit. I am only (re-writing) four files as they grow over time, but they should never exceed a fraction of the allocated space. For instance:
$ sudo mkdir /mnt/ramdisk
$ sudo mount -t tmpfs -o size=256m tmpfs /mnt/ramdisk
This gives a me an empty RAM disk of 256 MB:
$ df | grep ramdisk
tmpfs             262144        0    262144   0% /mnt/ramdisk
After a while the app hits 100%:
$ df | grep ramdisk
tmpfs             262144   260616      1528 100% /mnt/ramdisk
however, the files in the RAM disk only take up around 45 MB:
$ ls -laR /mnt/ramdisk/
/mnt/ramdisk/: total 4 drwxrwxrwt 5 root root 100 Nov 13 14:23 . drwxr-xr-x 3 root root 4096 Nov 13 00:16 .. drwxr-xr-x 2 pi pi 80 Nov 13 14:56 db drwxr-xr-x 2 pi pi 80 Nov 13 14:56 ph drwxr-xr-x 2 pi pi 60 Nov 13 14:44 tmp
/mnt/ramdisk/db: total 30580 drwxr-xr-x 2 pi pi 80 Nov 13 14:56 . drwxrwxrwt 5 root root 100 Nov 13 14:23 .. -rw-r--r-- 1 pi pi 15584348 Nov 13 14:56 db0.aif -rw-r--r-- 1 pi pi 15728348 Nov 13 14:56 db1.aif
/mnt/ramdisk/ph: total 13300 drwxr-xr-x 2 pi pi 80 Nov 13 14:56 . drwxrwxrwt 5 root root 100 Nov 13 14:23 .. -rw-r--r-- 1 pi pi 6842812 Nov 13 14:56 ph0.aif -rw-r--r-- 1 pi pi 6774716 Nov 13 14:55 ph1.aif
/mnt/ramdisk/tmp: total 2252 drwxr-xr-x 2 pi pi 60 Nov 13 14:44 . drwxrwxrwt 5 root root 100 Nov 13 14:23 .. -rw-r--r-- 1 pi pi 2305024 Nov 13 14:56 rec.irc
(15584348+15728348+6842812+6774716+2305024)/1024.0/1024 // 45 MB
Even taking a bit of overhead into account, how can the disk be full although the contents are less than 20% of the nominal capacity? And more importantly, how can I fix this? I cannot increase the allocated RAM much more than 256 MB, in fact 64 MB should be sufficient for the application.
Here is another approach, comparing df and du, the more the process goes on, the greater the discrepancy:
$ df -h | grep ramdisk
tmpfs           256M   35M  222M  14% /mnt/ramdisk
$ du -h /mnt/ramdisk/
2.2M    /mnt/ramdisk/tmp
11M /mnt/ramdisk/ph
6.6M    /mnt/ramdisk/db
20M /mnt/ramdisk/
I wouldn't mind if df as "off", but the application crashes when df reports 100% used. Interestingly, when I kill the app, the sizes start to line up again. So this looks like a "caching problem" or something related.
0__
  • 522
It seems to be a problem of keeping references to open files in Java (Scala), I guess the space of those is not reclaimed. E.g.
$ lsof -p <pid-of-process>
java 377068 user 92r REG 0,66 84 6 /mnt/ramdisk/ph/ph0.aif (deleted) java 377068 user 93r REG 0,66 54 5 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 94r REG 0,66 84 6 /mnt/ramdisk/ph/ph0.aif (deleted) java 377068 user 95r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 97r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 98r REG 0,66 1495192 13 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 99r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 100r REG 0,66 2304084 9 /mnt/ramdisk/ph/ph1.aif (deleted) java 377068 user 101r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 102r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 103r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 104r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 105r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 106r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 107r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 108r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 109r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 110r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 111r REG 0,66 576054 10 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 112r REG 0,66 2304084 9 /mnt/ramdisk/ph/ph1.aif (deleted) java 377068 user 113r REG 0,66 2304084 9 /mnt/ramdisk/ph/ph1.aif (deleted) java 377068 user 114r REG 0,66 2304084 9 /mnt/ramdisk/ph/ph1.aif (deleted) java 377068 user 115r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 116r REG 0,66 2305024 7 /mnt/ramdisk/tmp/rec.irc java 377068 user 117r REG 0,66 2515148 12 /mnt/ramdisk/ph/ph0.aif (deleted) java 377068 user 118r REG 0,66 1495192 13 /mnt/ramdisk/db/db0.aif (deleted) java 377068 user 119r REG 0,66 1495192 13 /mnt/ramdisk/db/db0.aif (deleted) ...
If I add up the sizes (column 7) of all the unique references (column 8) here, I come close to the space reported by df.
Edit: After debugging, I found a location in my code where files are opened but not closed. It seems that, at least when using the RAM disk, even though the files get overwritten, this prevents the backing memory from being freed.
0__
  • 522
