I want to stream the live video feed captured from a camera attached to my Raspberry Pi Zero to some browser with as low latency as possible (<1s). My end goal is attaching the Pi Zero & Camera to a drone and streaming the video via LTE.
However, I'm kind of lost in the jungle of different solutions that exist here (MJPEG, RTMP, RTSP, WebRTC).
So far, I tried a simple mjpeg streamer following this guide :
import cv2
import  pyshine as ps #  pip3 install pyshine==0.0.9
HTML=""" <html> <head> <title>PyShine Live Streaming</title> </head>
<body> <center><h1> PyShine Live Streaming using OpenCV </h1></center> <center><img src="stream.mjpg" width='320' height='240' autoplay playsinline></center> </body> </html> """ def main(): StreamProps = ps.StreamProps StreamProps.set_Page(StreamProps,HTML) address = ('127.0.0.1',9000) # Enter your IP address try: StreamProps.set_Mode(StreamProps,'cv2') capture = cv2.VideoCapture(0) if capture.isOpened(): capture.set(cv2.CAP_PROP_BUFFERSIZE,2) capture.set(cv2.CAP_PROP_FRAME_WIDTH,240) capture.set(cv2.CAP_PROP_FRAME_HEIGHT,320) capture.set(cv2.CAP_PROP_FPS,8) StreamProps.set_Capture(StreamProps,capture) StreamProps.set_Quality(StreamProps,40) server = ps.Streamer(address,StreamProps) print('Server started at','http://'+address[0]+':'+str(address[1])) server.serve_forever()
except KeyboardInterrupt:
    capture.release()
    server.socket.close()
if name=='main': main()
While the latency of this simple solution is sufficiently low, it's nowhere near robust enough for my use case. Whenever the connection is interrupted, the stream stops until the browser is refreshed. With slow internet, the stream tends to have a large delay (15s or more) after a while.
What kind of solution should I use for my use case?
Thanks for your help!
Wassermalone
For low latency, you really can't do better than an MJPEG stream.
The implementation put together by the RPi-Cam-Web-Interface project is very configurable and I get sub-second latency on my applications (although I'm not streaming through LTE so ymmv) Also this only works with Rpi camera port compatible cameras, so no USB cameras.
For the easiest set up you need to be on the same wifi network, but you can set it up with ngrok or have it vpn into your network with something like tinc
Not specific to your question but I put together a bit of python boilerplate for using the RPi-Cam-Web-Interface stream with CV tasks. Grabs the latest frame for some CV and then grabs the next one. Maybe it's useful for your application
import numpy as np
import urllib.request
import cv2
camera_name = "raspberrypi.local" stream = urllib.request.urlopen('http://' + camera_name +'/html/cam_pic.php')
WINDOW_NAME = "Camera" cv2.namedWindow(WINDOW_NAME) cv2.startWindowThread()
async def main(): while True: bytes += stream.read(1024) a = bytes.find(b'\xff\xd8') #frame starting b = bytes.find(b'\xff\xd9') #frame ending # new frame is available if a != -1 and b != -1: jpg = bytes[a:b+2] bytes = bytes[b+2:] frame = cv2.imdecode(np.frombuffer(jpg, dtype=np.uint8), cv2.IMREAD_COLOR)
        #do your CV stuff here
        cv2.imshow(WINDOW_NAME, frame)
        #get the next frame by adding any new string to the end of the url, here we use a timestamp
        url = 'http://' + camera_name +'/html/cam_pic.php?' + str(timestamp)
        #print(url)
        stream = urllib.request.urlopen(url)
