In the past, I set a static IP to my Raspberry Pi 3. Now, I want to use it to other purpose and the subnet has changed. I don't remember how I set it to static. I have looked some questions but no one applies to my case. I have check "interfaces" and "dhcpcd.conf". Both are like they suppose to be. When I try to modify dhcpcd.conf I get "Error writing dhcpcd.conf: no space left on device".
Unless you solve the no space left on device, you will not be able to change anything.
The easiest way to get some space is to throw away logging. Under /var/log there are many logs (probably). Anything ending in gz is probably fine to delete (unless you want to review old logs; in that case: move it to an USB-stick). You may also move some other stuff to a USB-stick.
In your /etc/dhcpcd.conf, you probably have lines like this (with other IP addresses, possibly)
interface eth0
static ip_address=192.168.178.53/24
static routers=192.168.178.1
static domain_name_servers=192.168.178.56
interface wlan0
static ip_address=192.168.178.3/24
Remove those lines (or make them comment).
And restart the dhcpcd:
systemctl restart dhcpcd.service
Or reboot.
Ljm Dullaart
  • 2,539
