I've read a few posts on here about this and I can't seem to solve it. The NTP service will not start with my pi.
Model 4B Revision 1.2 (4 GB)
I'm in a situation where the pi is blocked from internet but we have some local time servers setup. When I manually run:
   sudo ntpdate -s 192.168.2.247
This works fine and updates to the correct time from our local server, but the service will not start with the pi booting and I cant figure out why.
I have disabled systemd-timesyncd
Output of status on ntp: sudo service ntp status
● ntp.service - Network Time Service
   Loaded: loaded (/lib/systemd/system/ntp.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2022-09-23 17:16:34 MST; 1min 32s ago
     Docs: man:ntpd(8)
  Process: 468 ExecStart=/usr/lib/ntp/ntp-systemd-wrapper (code=exited, status=0/SUCCESS)
 Main PID: 499 (ntpd)
    Tasks: 2 (limit: 4915)
   CGroup: /system.slice/ntp.service
           └─499 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 111:116
Sep 23 17:16:34 allsky ntpd[499]: Listening on routing socket on fd #20 for interface updates Sep 23 17:16:34 allsky ntpd[499]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized Sep 23 17:16:34 allsky ntpd[499]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized Sep 23 17:16:44 allsky ntpd[499]: bind(23) AF_INET6 fe80::af86:b202:dbb6:9953%2#123 flags 0x11 failed: Cannot assi Sep 23 17:16:44 allsky ntpd[499]: unable to create socket on eth0 (4) for fe80::af86:b202:dbb6:9953%2#123 Sep 23 17:16:44 allsky ntpd[499]: failed to init interface for address fe80::af86:b202:dbb6:9953%2 Sep 23 17:16:46 allsky ntpd[499]: Listen normally on 5 eth0 [fe80::af86:b202:dbb6:9953%2]:123 Sep 23 17:16:46 allsky ntpd[499]: new interface(s) found: waking up resolver Sep 23 17:16:49 allsky ntpd[499]: Listen normally on 6 eth0 192.167.1.52:123 Sep 23 17:16:49 allsky ntpd[499]: new interface(s) found: waking up resolver
Config file:
cat /etc/ntp.conf
# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
Leap seconds definition provided by tzdata
leapfile /usr/share/zoneinfo/leap-seconds.list
Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats filegen loopstats file loopstats type day enable filegen peerstats file peerstats type day enable filegen clockstats file clockstats type day enable
You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example server 192.168.2.248 server 192.168.2.52 server 192.168.2.55 server 192.168.2.17 #server 192.168.2.16 #server 192.168.2.247
pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will
pick a different set every time it starts up. Please consider joining the
pool: <http://www.pool.ntp.org/join.html>
pool 0.debian.pool.ntp.org iburst #pool 1.debian.pool.ntp.org iburst #pool 2.debian.pool.ntp.org iburst #pool 3.debian.pool.ntp.org iburst
Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
details. The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions>
might also be helpful.
Note that "restrict" applies to both servers and clients, so a configuration
that might be intended to block requests from certain clients could also end
up blocking replies from your own upstream servers.
By default, exchange time with everybody, but don't allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery limited restrict -6 default kod notrap nomodify nopeer noquery limited
Local users may interrogate the ntp server more closely.
restrict 127.0.0.1 restrict ::1
Needed for adding pool entries
restrict source notrap nomodify noquery
Clients from this (example!) subnet have unlimited access, but only if
cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
If you want to provide time to your local subnet, change the next line.
(Again, the address is an example only.)
#broadcast 192.168.123.255
If you want to listen to time broadcasts on your local subnet, de-comment the
next lines. Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
timedatectl status
               Local time: Fri 2022-09-23 17:21:14 MST
           Universal time: Sat 2022-09-24 00:21:14 UTC
                 RTC time: n/a
                Time zone: America/Phoenix (MST, -0700)
System clock synchronized: no
              NTP service: inactive
          RTC in local TZ: no
Thanks!
Rankinstudio
  • 111
These instructions seemed to fix the issue, npt starts with the pi and syncs time now:
sudo apt install ntp
sudo systemctl stop systemd-timesyncd
sudo systemctl disable systemd-timesyncd
sudo systemctl enable ntp
sudo systemctl start ntp
Rankinstudio
  • 111
