I am using latest the Raspbian Wheezy release with kernel 3.10. I am running four Python programs 24 hours/day on the Raspberry Pi. Three programs out of four are like background services, which consume at the maximum 2.4% CPU and around 1.2% memory each. The fourth Python code is a pygame application that is displayed on a 1920x1080 screen, which consumes about 50% CPU and 2.4% memory. Thus in total when I am running all 4 programs total memory used is 90 MB and 60% CPU is in use all the time.
The problem is that Raspberry Pi suddenly hangs (no response the keyboard nor mouse, and I'm also not able to ping) after 2-3 days and thus we have to reboot it forcefully. What could be the reason for it to hang? There is no problem of a memory leak since even after 2-3 days the total memory usage and CPU usage is unchanged.
Fred
  • 4,592
  • 29
prattom
  • 165
What do you mean by "hang"? I had problems with my headless pi that every 2-3 days I could not connect to it. It was working ok but I could not ping nor ssh to it. Turned out to be a problem with the power management in the wifi dongle:
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=51543&p=397663
Once I turned of the power management features as described in the link it worked continuously again
Jason
  • 61
If you overclocked, double check that and maybe set a lower frequency. One does not simply set "Turbo" or "Pi2" as an overclock in raspi-config. I've experienced this with extreme stress testing and a serious overclock. Clocking down solved my issue.
Aloha
  • 7,176
  • 29
  • 52
