I have a raspberry pi 3 with Debian os and I am unable to connect to it via ssh through VS code.The pi has already been configured and has a username and password.
The raspberry pi shows the message ‘couldn’t find an input interrupt endpoint’ before launching.
Here are the steps I follow:
Enable SSH on the pi and find out its local IP address and connect the pi and the laptop on the same wifi.Delete the SSH folders at C:\Program Data\ and C:<user>\ username\
Install remote SSH in vs code and add new host.
It then asks for the ssh connection command and I enter ssh rpiusername@ipadrress.
It then creates the .ssh file at C:\Users\username.ssh.
The host gets added and then I chose linux as the platform for the remote host.
It asks to continue and then asks for the password.
I enter the password and it gets rejected 3 times.
Finally it says it couldn’t establish connection and permission denied(Public key,password)
Here is what I get in the terminal
Log Level: 2
remote-ssh@0.85.2022071315
win32 x64
SSH Resolver called for "ssh-remote+192.168.0.171", attempt 1
"remote.SSH.useLocalServer": false
"remote.SSH.showLoginTerminal": false
"remote.SSH.remotePlatform": {}
"remote.SSH.path": undefined
"remote.SSH.configFile": C:\Users\username.ssh
"remote.SSH.useFlock": true
"remote.SSH.lockfilesInTmp": false
"remote.SSH.localServerDownload": auto
"remote.SSH.remoteServerListenOnSocket": false
"remote.SSH.defaultExtensions": []
"remote.SSH.loglevel": 2
"remote.SSH.enableDynamicForwarding": true
"remote.SSH.enableRemoteCommand": false
"remote.SSH.serverPickPortsFromRange": {}
"remote.SSH.serverInstallPath": {}
SSH Resolver called for host: 192.168.0.171
Setting up SSH remote "192.168.0.171"
Using commit id "3b889b090b5ad5793f524b5d1d39fda662b96a2a" and quality "stable" for server
Install and start server if needed
Checking ssh with "ssh -V"
> OpenSSH_for_Windows_8.1p1,
> LibreSSL 3.0.2
Using SSH config file "C:\Users\username.ssh"
Running script with connection command: ssh -T -D 51236 -F "C:\Users\username.ssh"
"192.168.0.171" bash
Terminal shell path: C:\WINDOWS\System32\cmd.exe
> The authenticity of host '192.168.0.171 (192.168.0.171)' can't be established.
> ECDSA key fingerprint is SHA256:sJz0W0rNvgccVE9FCqqkRv4LoGOrlBUI8Y0p+8yznCs.
> Are you sure you want to continue connecting (yes/no/[fingerprint])?
]0;C:\WINDOWS\System32\cmd.exe
Got some output, clearing connection timeout
Detected fingerprint confirmation message
Showing fingerprint confirmation dialog
Got fingerprint response: yes
"install" wrote data to terminal: "yes"
> y
> es
> Failed to add the host to the list of known hosts (C:\Users\username/.ssh/known_hosts).
> raspberrypi@192.168.0.171's password:
Showing password prompt
Got password response
"install" wrote data to terminal: "**********"
> Permission denied, please try again.
> raspberrypi@192.168.0.171: Permission denied (publickey,password).
> The process tried to write to a nonexistent pipe.
"install" terminal command done
Install terminal quit with output: raspberrypi@192.168.0.171: Permission denied
Received install output: raspberrypi@192.168.0.171: Permission denied (publickey,password).
Resolver error: Error: Permission denied (publickey,password).
at Function.Create (c:\Users\username\.vscode\extensions\ms-vscode-remote.remote-ssh-
0.85.2022071315\out\extension.js:1:588535)
at c:\Users\username\.vscode\extensions\ms-vscode-remote.remote-ssh-
0.85.2022071315\out\extension.js:1:586592
at Object.t.handleInstallOutput (c:\Users\username\.vscode\extensions\ms-vscode-
remote.remote-ssh-0.85.2022071315\out\extension.js:1:587109)
at Object.t.tryInstall (c:\Users\username\.vscode\extensions\ms-vscode-remote.remote-
ssh-0.85.2022071315\out\extension.js:1:684336)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async c:\Users\username\.vscode\extensions\ms-vscode-remote.remote-ssh-
0.85.2022071315\out\extension.js:1:647221
at async Object.t.withShowDetailsEvent (c:\Users\username\.vscode\extensions\ms-vscode-
remote.remote-ssh-0.85.2022071315\out\extension.js:1:650537)
at async Object.t.resolve (c:\Users\username\.vscode\extensions\ms-vscode-remote.remote-
ssh-0.85.2022071315\out\extension.js:1:648271)
0.85.2022071315\out\extension.js:1:730993
I am 95% sure I am entering the correct password.I am unable to figure out the error so please help.
