EDIT
this apprears to be a software issue. I booted another RPI with a fresh OS and it showed 1GB of ram. I then booted it off the HDD that I am using for the other rpi and it showed that there was only 114MB of ram. Still not even sure where to look.
Original Post
I am trying to figure out if I screwed something up. I have a 3B+, which says it has 1GB LPDDR2 SDRAM on the spec page (https://www.raspberrypi.com/products/raspberry-pi-3-model-b-plus/). However, while looking at htop one day, I noticed it said 114M of ram... and free agrees. I am assuming 1GB of ram means one billion bytes and not bits, seeing that capitol B.
I checked on my raspberry pi 3B, and indeed that one says it has 926M available, so I'm not going totally crazy.
It keeps dumping things to swap, which is slowing things down a ton. Below are all the details that I can think to give.
$ free -h
total used free shared buff/cache available
Mem: 113M 65M 29M 32K 18M 14M
Swap: 1.2G 231M 1.0G
I made a tmpfs disk with 100MB of storage, and I am trying to figure out if I screwed something up when I made this.
I also see I have a bunch of tmpfs when I run df , but my understanding is they only use the ram that is being stored in them, and do not block off everything else.
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 110G 9.4G 97G 9% /
devtmpfs 53M 0 53M 0% /dev
tmpfs 57M 8.0K 57M 1% /dev/shm
tmpfs 57M 6.6M 51M 12% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 57M 0 57M 0% /sys/fs/cgroup
tmpfs 100M 3.5M 97M 4% /home/pi/webpage/rtmp
/dev/sda1 44M 39M 4.7M 90% /boot
tmpfs 12M 0 12M 0% /run/user/1000
here is the /etc/fstab file
$ cat /etc/fstab
tmpfs /home/pi/webpage/rtmp tmpfs defaults,nodev,exec,mode=1777,size=100M,uid=pi,gid=www-data 0 0
proc /proc proc defaults 0 0
PARTUUID=82ca2376-01 /boot vfat defaults 0 2
PARTUUID=82ca2376-02 / ext4 defaults,noatime 0 1
swap_file swap swap defaults 0 0
