I'm a new member of the raspberry pi community and I have problems with starting my first project. I want to be able to create a data signal using pulse width modulation with the gpio headers. The duty cycle would determine the value of a bit. so for example 75% duty cycle would represent a 1 and a 25% duty cycle would represent a 0. So I have to be able to control the amplitude of the signal very precicely since I want the frequency of the signal to be around 10000 hertz. The data signal would be used to control a LED strip. I want to write the software from the ground up. How would one go about this? I know python and a little bit of c++.
Thanks!
Choose a GPIO library.
See https://elinux.org/RPi_GPIO_Code_Samples
Write the code.
joan
  • 71,852
  • 76
  • 108
"I want to write the software from the ground up."
  1. Read the Peripheral documentation https://www.raspberrypi.com/documentation/computers/processors.html
  2. Choose a language
  3. Write the code.
"I have problems with starting my first project."
There are a few caveats; I would NOT start with PWM which is involved and has limited support.
You might like to read the survey of available libraries I wrote a couple of years ago https://raspberrypi.stackexchange.com/a/117592/8697
