This is another "RPI does not boot". I have tried many thins now and I'm not able to figure out why my RPI4 (that is quite valuable these days) does not boot. EEPROM is working fine and I followed this post to output the early boot log to UART. This is what I get:
RPi: BOOTLOADER release VERSION:507b2360 DATE: 2022/04/26 TIME: 11:24:28 BOOTMODE: 0x00000006 part: 0 BUILD_TIMESTAMP=1650968668 0x470108a2 0x00b03111 0x0006668c
PM_RSTS: 0x00001000
part 00000000 reset_info 00000000
uSD voltage 3.3V
Initialising SDRAM 'Micron' 16Gb x1 total-size: 16 Gbit 3200
DDR 3200 0 0 16 152
XHCI-STOP xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb USBSTS 11 xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb xHC ports 5 slots 32 intrs 4 Reset USB port-power 1000 ms xhci_set_port_power 1 0 xhci_set_port_power 2 0 xhci_set_port_power 3 0 xhci_set_port_power 4 0 xhci_set_port_power 5 0 xhci_set_port_power 1 1 xhci_set_port_power 2 1 xhci_set_port_power 3 1 xhci_set_port_power 4 1 xhci_set_port_power 5 1 XHCI-STOP xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb USBSTS 18 XHCI-STOP xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb USBSTS 19 xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb xHC ports 5 slots 32 intrs 4 Boot mode: SD (01) order f54 USB2[1] 400202e1 connected USB2 root HUB port 1 init DEV [01:00] 2.16 000000:01 class 9 VID 2109 PID 3431 HUB init [01:00] 2.16 000000:01 SD HOST: 250000000 CTL0: 0x00000000 BUS: 200000 Hz actual: 200000 HZ div: 1250 (625) status: 0x1fff0000 delay: 540 SD HOST: 250000000 CTL0: 0x00000f00 BUS: 200000 Hz actual: 200000 HZ div: 1250 (625) status: 0x1fff0000 delay: 540 OCR c0ff8000 [2] CID: 002750485344333247606c6ac0cc0143 CSD: 400e00325b590000e7177f800a400000 SD: bus-width: 4 spec: 2 SCR: 0x02058083 0x01000000 SD HOST: 250000000 CTL0: 0x00000f04 BUS: 50000000 Hz actual: 41666666 HZ div: 6 (3) status: 0x1fff0000 delay: 2 MBR: 0x00002000, 524288 type: 0x0c MBR: 0x00082000, 7913472 type: 0x83 MBR: 0x00000000, 0 type: 0x00 MBR: 0x00000000, 0 type: 0x00 Trying partition: 0 type: 32 lba: 8192 oem: 'mkfs.fat' volume: ' boot ' rsc 32 fat-sectors 4033 c-count 516190 c-size 1 root dir cluster 2 sectors 0 entries 0 FAT32 clusters 516190 Trying partition: 0 type: 32 lba: 8192 oem: 'mkfs.fat' volume: ' boot ' rsc 32 fat-sectors 4033 c-count 516190 c-size 1 root dir cluster 2 sectors 0 entries 0 FAT32 clusters 516190 Read config.txt bytes 2075 hnd 0x51b Read start4.elf bytes 2241824 hnd 0xf1f1 Read fixup4.dat bytes 5352 hnd 0x52f Firmware: e5a963efa66a1974127860b42e913d2374139ff5 Mar 24 2022 13:19:26 0x00b03111 0x00000000 0x00000fff MEM GPU: 76 ARM: 948 TOTAL: 1024 Starting start4.elf @ 0xfec00200 partition 0 XHCI-STOP xHC ver: 256 HCS: 05000420 fc000031 00e70004 HCC: 002841eb USBSTS 18
I don't really know how to read this, so any help is welcome. Another detail: I'm measuring the current consumption of the RPI connection and I get the expected 400-500mA when the boot sequence starts, but it drops to a constant ~300mA the moment the sequence stops (when the log stops as well).
Miguel
  • 233
