I'm on Raspberry Pi OS Bullseye, using a Pi 3B. The error message is differing from the ones I could find on previous posts, and there are different fixes by changing dtoverlay in /boot/config.txt. Last time I re-enabled the Legacy stack camera at least that worked but it completely bugged the whole system, making it impossible to connect via VNC and many other unrelated things... I could not find a solution to this, here's what it tells me:
libEGL warning: DRI2: failed to authenticate
Made X/EGL preview window
[0:13:54.365083754] [3458] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3544-22656360
[0:13:54.405175545] [3474] ERROR CameraSensor camera_sensor.cpp:591 'ov5647 10-0036': Camera sensor does not support test pattern modes.
[0:13:54.468034105] [3474] INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[0:13:54.469572692] [3458] INFO Camera camera.cpp:1029 configuring streams: (0) 1296x972-YUV420
[0:13:54.470488521] [3474] INFO RPI libEGL warning: DRI2: failed to authenticate
[0:13:54.470488521] [3474] INFO RPI raspberrypi.cpp:760 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 1296x972-SGBRG10_1X10 - Selected unicam format: 1296x972-pGAA
terminate called after throwing an instance of 'std::runtime_error'
what(): failed to import fd 19
Abgebrochen
Abgebrochen
