Initial Connection to the RPi is flawless, even with VS Code Remote Dev. But after some time (without special command) the RPi closes the connection ("Connection to 10.0.0.11 closed by remote host"). In Debug mode it says following right before:
debug3: send packet: type 1
debug1: channel 0: free: client-session, nchannels 1
debug3: channel 0: status: The following connections are open:
#0 client-session (t4 r0 i0/0 o0/0 e[write]/0 fd 4/5/6 sock -1 cc -1)
debug3: Successfully set console output code page from 65001 to 65001
debug3: Successfully set console input code page from 65001 to 850
Connection to 10.0.0.11 closed by remote host.
Connection to 10.0.0.11 closed.
Transferred: sent 3684, received 93440 bytes, in 115.0 seconds
Bytes per second: sent 32.0, received 812.2
debug1: Exit status -1
I have a Node.js Server running, with PM2 to restart on crash and just installed a HTTPS Certificate with Certbot.
Edit
This is how the connection's idle and suddently closes
Linux raspberrypi-webserver 5.15.32-v7+ #1538 SMP Thu Mar 31 19:38:48 BST 2022 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Apr 25 20:51:26 2022 from 10.0.0.138
admin@raspberrypi-webserver:~ $ debug3: send packet: type 80
debug3: receive packet: type 82
Connection to **.ddns.net closed by remote host.
Connection to **.ddns.net closed.
Transferred: sent 2276, received 4108 bytes, in 304.0 seconds
Bytes per second: sent 7.5, received 13.5
C:\Users****>
Does anybody know why this happens?
