I have built a custom Linux OS for Raspberry Pi CM4 using Buildroot. I am able to boot it but my system clock is not synchronized. Its set to some static time and I want to show real time instead. I have selected BR2_PACKAGE_RTC_TOOLS=y, BR2_PACKAGE_UTIL_LINUX_HWCLOCK=y and BR2_PACKAGE_NTP=y, BR2_PACKAGE_NTP_NTPDATE=y, BR2_PACKAGE_NTP_NTPTIME=y in menuconfig. But still it's same result.
The timedatectl shows:
Local time: Tue 2022-01-18 11:52:05 UTC
           Universal time: Tue 2022-01-18 11:52:05 UTC
                 RTC time: n/a
                Time zone: Etc/UTC (UTC, +0000)
System clock synchronized: no
              NTP service: active
          RTC in local TZ: no
The systemctl status systemd-timesyncd shows:
systemd-timesyncd.service - Network Time Synchronization
     Loaded: loaded (/usr/lib/systemd/system/systemd-timesyncd.service; enabled;
     Active: active (running) since Tue 2022-01-18 11:35:47 UTC; 17min ago
       Docs: man:systemd-timesyncd.service(8)
   Main PID: 194 (systemd-timesyn)
     Status: "Daemon is running"
      Tasks: 1 (limit: 1009)
        CPU: 396ms
     CGroup: /system.slice/systemd-timesyncd.service
             └─194 /usr/lib/systemd/systemd-timesyncd
Jan 18 11:35:46 br2rauc systemd[1]: Starting Network Time Synchronization... Jan 18 11:35:47 br2rauc systemd[1]: Started Network Time Synchronization.
And timedatectl show-timesync results in:
FallbackNTPServers=time1.google.com time2.google.com time3.google.com time4.google.com
RootDistanceMaxUSec=5s
PollIntervalMinUSec=32s
PollIntervalMaxUSec=34min 8s
PollIntervalUSec=0
Frequency=0
I don't know why but /etc/systemd/timesyncd.conf looks like not set
[Time]
#NTP=
#FallbackNTP=time1.google.com time2.google.com time3.google.com time4.google.com
#RootDistanceMaxSec=5
#PollIntervalMinSec=32
#PollIntervalMaxSec=2048
#SaveIntervalSec=60
Do I need to set any value for NTP?
I also tried by enabling BR2_PACKAGE_HTPDATE=y and systemctl status htpdate.status shows:
htpdate.service - htpdate daemon
     Loaded: loaded (/usr/lib/systemd/system/htpdate.service; enabled; vendor pr
     Active: active (running) since Tue 2022-01-18 11:35:48 UTC; 22min ago
    Process: 221 ExecStart=/usr/sbin/htpdate -D -i /run/htpdate.pid $HTPDATE_ARG
   Main PID: 228 (htpdate)
        CPU: 26ms
     CGroup: /system.slice/htpdate.service
             └─228 /usr/sbin/htpdate -D -i /run/htpdate.pid -a -s -t https:/
Jan 18 11:35:48 br2rauc systemd[1]: Starting htpdate daemon... Jan 18 11:35:48 br2rauc htpdate[228]: htpdate version 1.3.3 started Jan 18 11:35:48 br2rauc htpdate[228]: www.google.com host or service unavailable Jan 18 11:35:48 br2rauc systemd[1]: Started htpdate daemon.
As you can see above date and time is set to Jan 18. While booting Pi is not connected to internet. And I connect to internet using connman after system boot. But again after restarting systemd-timesyncd it's same result.
Can anyone please let me know how to properly synchronize the system clock?
Your help will be much appreciated.
thanks in advance
P.S: Please let me know if any info is missing here.
Preeti
  • 137
