I'm trying to connect x9 RC522 RFID readers to an RPI.
I'm wondering if it can be done using the standard RPi GPIO pins or if I need some other controller.
Also, it's worth mentioning that it will need to be able to distinguish between the readers, and know which one is providing which data.
And I'm not sure if I use a port expander, something like this, if the data stream will get "tagged" to identify which reader it came from.
Kaigo
  • 163
did this exact thing using 5x RFID-RFC522 Readers.
You can use the RST Pins to select the reader you want to use. Connect all the other pins in parallel (see schematic below). Just set all the RST pins to low, except the one on the pin you want to use. Set that one to high. Then initialize SPI, read/write, and close SPI again.
I wrote a more detailed explanation here.
This is the schematics and code I made:
Schematic for 2 readers: Schematic for 2 readers
Schematic for 4 readers: Schematic for 4 readers
Code to run it all (using pimylifeup's MFRC522-Python Library):
import RPi.GPIO as GPIO
from mfrc522 import SimpleMFRC522
import spidev
class NFC(): def init(self, bus=0, device=0, spd=1000000): self.reader = SimpleMFRC522() self.close() self.bus self.boards = {}
    self.bus = bus
    self.device = device
    self.spd = spd
def reinit(self):
    self.reader.READER.spi = spidev.SpiDev()
    self.reader.READER.spi.open(self.bus, self.device)
    self.reader.READER.spi.max_speed_hz = self.spd
    self.reader.READER.MFRC522_Init()
def close(self):
    self.reader.READER.spi.close()
def addBoard(self, rid, pin):
    self.boards[rid] = pin
def selectBoard(self, rid):
    if not rid in self.boards:
        print("readerid " + rid + " not found")
        return False
    for loop_id in self.boards:
        GPIO.output(self.boards[loop_id], loop_id == rid)
    return True
def read(self, rid):
    if not self.selectBoard(rid):
        return None
    self.reinit()
    cid, val = self.reader.read_no_block()
    self.close()
    return val
def write(self, rid, value):
        return False
    self.reinit()
    self.reader.write_no_block(value)
    self.close()
    return True
if name == "main": nfc = NFC() nfc.addBoard("reader1",5) nfc.addBoard("reader2",6)
data = nfc.read("reader1")
nfc.write("reader2",data)
Lugico
  • 41
I found a few issues with the code while trying to run it on my Raspberry Pi 3...
  1. in the init area, the first self.bus throws an error because it's not being set to anything. a few lines down you do set it a value, so I removed the first instance of it, and it cleared that error.
  2. when the code gets to the nfc.read function, an error is thrown during the FOR loop in the self.SelectBoard function. the error is "Runtime Error: the GPIO channel has not been set up as an OUTPUT." this was fixed by adding the following line of code to the self.addboard function... GPIO.setup(pin, GPIO.OUT) that sets whatever pin you are using as the reset/chip select pin to an output. after these changes, the code runs smoothly.
I hope this helps anyone who is also using multiple of these RFID-RC522 modules for anything.
