I was trying to install docker and accidentally ran a script I wasn't meant to (yeah I know) and now I have lost all my apt-get binaries.
I have tried looking through http://raspbian.raspberrypi.org/raspbian/pool/main/a/apt/ but none of those debian packages seem to work. Is there a way I can get my apt binaries back without having to reimage?
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
jabroni
  • 101
Welcome. On the bright side, this may be a good opportunity to upgrade to bullseye ;)
Here's a weird thing: I tried an apt install --reinstall --download-only apt to see where it gets the package from, and it's http://ftp.debian.org/debian/pool/main/a/apt/apt_1.8.2.3_arm64.deb That's the 64-bit version, the 32-bit one would be http://ftp.debian.org/debian/pool/main/a/apt/apt_1.8.2.3_armhf.deb.
However, I then pulled the apt binary out (.deb packages are .cpio files in disguise), and there's a problem with the things it depends on:
    > ldd ./apt
    linux-vdso.so.1 (0x0000007fb84aa000)
    libapt-private.so.0.0 => /usr/lib/aarch64-linux-gnu/libapt-private.so.0.0 (0x0000007fb83e5000)
    libapt-pkg.so.6.0 => not found
There's more, but the issue here is the "not found"; compare to the actual apt on the system:
    > ldd $(which apt)
    linux-vdso.so.1 (0x0000007f97f9c000)
    libapt-private.so.0.0 => /usr/lib/aarch64-linux-gnu/libapt-private.so.0.0 (0x0000007f97ed7000)
    libapt-pkg.so.5.0 => /usr/lib/aarch64-linux-gnu/libapt-pkg.so.5.0 (0x0000007f97d15000)
It is linked against an earlier version of libapt-pkg. Note that if I run apt install apt without --reinstall I get told it is already up to the latest version, which makes sense since both binaries are 1.8.2.3.
I think you can see here how doing this kind of repair can quickly blossom into one task after another. Bases on your question, you have lost at least your apt-get binaries; even if you get them back there may be more problems waiting for you.
The truth is, you've partially trashed the system by accident. There's a couple of things to learn from that:
  • Be careful when using root/sudo powers.
  • KEEP BACK_UPS and perhaps notes so you can easily re-install. You could also learn to use an automated system like puppet, or simply keep notes and try to write scripts to do the same, and keep those backed up.
How can I reinstall without re-imaging?
Unless you're ascetic, don't waste your time. It's too late for a backup (more on that shortly), but you need not lose anything of value:
  1. Remove the SD card (yes - the one you've trashed) from your RPi, and set it aside in a safe place.
  2. Flash a new card & re-start your RPi
  3. Put your trashed SD card in a USB-SD adapter, insert that into a USB port on your newly-flashed system, and mount it.
You can now copy any file from your trashed system to your new system.
For backups, I use the image-utils scripts. A "how-to" was posted about a year ago that will help you get underway quickly. FWIW, I create a "base" image once a month, and incrementally update it every night in a cron job so I'll never lose more than 24 hours of changes.
Seamus
  • 23,558
  • 83
