Please note this is not a duplicate of How to disable the dynamic IP address after assigning a static IP in Bullseye? this previous problem occurred when a system that was updated from Buster to Bullseye.
I have a new install of Bullseye on Raspberry Pi 3B. It is connected to a TP-Link Archer AX50 router running stock firmware. I had a static IP address setup with the following addition to the file /etc/dhcpcd.conf:
interface eth0
static ip_address=192.168.0.65/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
Following the advice of @Seamus, See this answer:
IP address missing from router DCHP table
I removed the last three lines and made the following change.
interface eth0
inform 192.168.0.65
Now I have two IP addresses. The command hostname I and sudo dhclient -vshow:
$ hostname -I
192.168.0.65 192.168.0.146
$ sudo dhclient -v
[sudo] password for sushenjit:
Internet Systems Consortium DHCP Client 4.4.1
Copyright 2004-2018 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
RTNETLINK answers: Operation not possible due to RF-kill
Listening on LPF/wlan0/b8:27:eb:f9:be:df
Sending on LPF/wlan0/b8:27:eb:f9:be:df
Listening on LPF/eth0/b8:27:eb:ac:eb:8a
Sending on LPF/eth0/b8:27:eb:ac:eb:8a
Sending on Socket/fallbackreceive_packet failed on wlan0: Network is down
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
send_packet: Network is down
dhclient.c:2446: Failed to send 300 byte long packet over wlan0 interface.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
DHCPOFFER of 192.168.0.146 from 192.168.0.1
DHCPREQUEST for 192.168.0.146 on eth0 to 255.255.255.255 port 67
DHCPACK of 192.168.0.146 from 192.168.0.1
bound to 192.168.0.146 -- renewal in 2852 seconds.
$ ip address show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:ac:eb:8a brd ff:ff:ff:ff:ff:ff
inet 192.168.0.65/24 brd 192.168.0.255 scope global noprefixroute eth0
inet 192.168.0.146/24 brd 192.168.0.255 scope global secondary dynamic eth0
valid_lft 4479sec preferred_lft 4479sec
inet6 fe80::9f8c:f503:5a46:ab25/64 scope link
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether b8:27:eb:f9:be:df brd ff:ff:ff:ff:ff:ff
Note, the TP-Link Archer AX50 assigns dynamic IP addresses in the range of: 192.168.0.100-192.168.0.249.
I don’t want the dynamic IP address 192.168.0.146 assigned to my Pi. However, I only want the 192.168.0.65 IP address. How do I do this without reverting the change?
Edit: Output of systemctl status dhcpcd:
$ systemctl status dhcpcd
● dhcpcd.service - DHCP Client Daemon
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-03-31 17:22:10 EDT; 2h 30min ago
Docs: man:dhcpcd(8)
Process: 416 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCESS)
Main PID: 490 (dhcpcd)
Tasks: 2 (limit: 1597)
CPU: 53min 45.506s
CGroup: /system.slice/dhcpcd.service
├─490 /usr/sbin/dhcpcd -b -q
└─556 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
Mar 31 19:52:59 raspberrypi dhcpcd[490]: eth0: received approval for 192.168.0.65
Thanks
