I've been tring to set up rspamd on a 4GB Pi 4, running an uptodate 64-bit Raspberry OS 11. After a successful install, running "systemctl status rspamd.service" displays:
 rspamd.service - rapid spam filtering system
 Loaded: loaded (/lib/systemd/system/rspamd.service; enabled; vendor preset: enabled)
 Active: failed (Result: signal) since Mon 2022-03-28 12:20:39 BST; 10s ago
   Docs: https://rspamd.com/doc/
Process: 46649 ExecStart=/usr/bin/rspamd -c /etc/rspamd/rspamd.conf -f
 (code=killed, signal=SEGV)
 Main PID: 46649 (code=killed, signal=SEGV)
    CPU: 48ms
Mar 28 12:20:39 hallpi systemd[1]: rspamd.service: Main process exited, code=killed, status=11/SEGV Mar 28 12:20:39 hallpi systemd[1]: rspamd.service: Failed with result 'signal'.
I've done some searching, and I'm prerty sure this is because I'm running a 64-bit OS, but I can't find any solutions, or anyone else with the same issue on a Raspberry Pi.
Has anyone here come across this, or found a fix?
Josey
  • 41
In the end I decided to install rspamd from source because I couldn't get the apt package to work on 64-bit Raspberry Pi OS.
Here's what I did (I'm sure it could be done better, but it worked):
cd ~
sudo apt install rspamd
mkdir rspamdconfig
sudo mv /etc/rspamd/* rspamdconfig/rspamd
sudo apt purge rspamd
sudo apt autopurge
sudo rm -r /etc/rspamd/
mkdir rspamd.build cd rspamd.build git clone --recursive https://github.com/rspamd/rspamd.git mkdir rspamd.build cd rspamd.build
sudo apt install cmake ragel pkg-config liblua5.1-dev libglib2.0-dev libsqlite3-dev libicu-dev libmagic-dev libssl-dev redis libsodium-dev lua5.4
nano ../rspamd/CMakeLists.txt
Change:
OPTION(WANT_SYSTEMD_UNITS "Install systemd unit files on Linux [default: OFF]" OFF)
to
OPTION(WANT_SYSTEMD_UNITS "Install systemd unit files on Linux [default: OFF]" ON)
cmake ../rspamd -DENABLE_LUAJIT=OFF
make -j8
sudo make install
sudo ln -s /usr/local/bin/rspamadm-3.3 /usr/bin/rspamadm-3.3 sudo ln -s /usr/local/bin/rspamadm-3.3 /usr/bin/rspamadm sudo ln -s /usr/local/bin/rspamc-3.3 /usr/bin/rspamc-3.3 sudo ln -s /usr/local/bin/rspamc-3.3 /usr/bin/rspamc sudo ln -s /usr/local/bin/rspamd-3.3 /usr/bin/rspamd-3.3 sudo ln -s /usr/local/bin/rspamd-3.3 /usr/bin/rspamd sudo ln -s /usr/local/bin/rspamd_stats /usr/bin/rspamd_stats
sudo mkdir /etc/rspamd sudo mv rspamdconfig/rspamd/* /etc/rspamd/ sudo chown -R root:root /etc/rspamd/
sudo mkdir /var/log/rspamd/ sudo touch /var/log/rspamd/rspamd.log sudo chown -R _rspamd:_rspamd /var/log/rspamd/
sudo systemctl start rspamd.service sudo systemctl enable rspamd.service systemctl status rspamd.service cd ~ rm -rf rspamd.build/ rm -rf rspamdconfig/
Josey
  • 41
