I'm planning a setup with an rpi3b+ and the pijuice hat (battery) and pijuice solar module. It is key to my project that I can access the following data digitally i.e. in the pi:
  • current power consumption of the pi
  • current power output from the solar panel
  • battery charge in %
The pijuice hat connects directly to the pi's 40-pin gpio header and is already supplying me with the battery charge in percent. The panel is plugged into the power management board (hat).
What components do I need to measure the consumption of the pi and the output from the panel?
rn42v
What you are describing is a coulomb counter. Looking at the pijuice Hat you linked to I do not see that function. Take a look at Grove coulomb counter, it is based on the LTC2941 by analog devices. It is also sold in the Arduino arena. There are several available from different sources and/or you can make your own.
Gil
  • 1,288
It was in their documentation all along, I was simply looking for the wrong thing. Both input and output can the read via their api.
rn42v
