I got a 5.8" eink display from Pervasive Displays and cannot get it to work, I feel that only a little bit is missing. After a lot of struggle I managed to run it via their sample C code, but the ported code to Python doesn't work. First the hardware details:
I connected it as described here: https://embeddedcomputing.weebly.com/connecting-the-ext3-to-the-raspberry-pi.html then simplified the example code to a bare minimum here this works fine, it displays the sample image. Its a bit tricky stuff, since it instructs to run the code in a Arduino emulator (RasPiArduino).
Here is my code for the bare minimum code that should work (it should trigger a display refresh), but nothing happens:
import spidev # SPI library
import time
import RPi.GPIO as GPIO
from images import BW_0x00Buffer, BW_monoBuffer # just arrays with hex numbers, see repo
class board_EXT3:
# EXT3 pin 1 Black -> +3.3V
# EXT3 pin 2 Brown -> GPIO 11 SPI0 SCLK
panelBusy = 7 # EXT3 pin 3 Red -> GPIO7 pin 26 (SPI chip select 1 / CE1)
panelDC = 8 # EXT3 pin 4 Orange -> GPIO8 pin 24 (SPI chip select 0 / CE0)
panelReset = 25 # EXT3 pin 5 Yellow -> GPIO25 pin 22
panelCS = 27 # EXT3 pin 9 Grey -> GPIO27 pin 13
# EXT3 pin 6 Green -> GPIO9 SPI0 MISO
# EXT3 pin 7 Blue -> GPIO10 SPI0 MOSI
flashCS = 22 # EXT3 pin 8 Violet -> GPIO22 pin 15
# EXT3 pin 10 White -> GROUND
def COG_initial():
GPIO.setup(board_EXT3.panelBusy, GPIO.IN) # all pins 0
GPIO.setup(board_EXT3.panelDC, GPIO.OUT)
GPIO.output(board_EXT3.panelDC, GPIO.HIGH)
GPIO.setup(board_EXT3.panelReset, GPIO.OUT)
GPIO.output(board_EXT3.panelReset, GPIO.HIGH)
GPIO.setup(board_EXT3.panelCS, GPIO.OUT)
GPIO.output(board_EXT3.panelCS,GPIO.HIGH)
global spi
spi = spidev.SpiDev()
spi.close()
spi.open(0, 0) # device 0 (SPI_CE0_N)
spi.max_speed_hz = 122000 # bit rate, was 8000000 should be OK too
spi.lsbfirst = False
spi.mode = 0b00 # polarity CPOL=0 CPHA=0, bits
spi.bits_per_word = 8 # read only on the Pi
def globalUpdate(data1s, data2s):
print("reset")
_reset() # needed for min
print("soft start")
_DCDC_softStart_Mid() # needed for min
print("refresh")
_displayRefresh() # needed for min
print("shutdown")
_DCDC_softShutdown_Mid()
def _reset():
time.sleep(0.2)
GPIO.output(board_EXT3.panelReset, GPIO.HIGH) # RES = 1
time.sleep(0.02)
GPIO.output(board_EXT3.panelReset, GPIO.LOW)
time.sleep(0.2)
time.sleep(0.05)
GPIO.output(board_EXT3.panelCS, GPIO.HIGH)
time.sleep(0.005)
def _DCDC_softStart_Mid():
# Initialize COG Driver
data4 = [0x7d]
_sendIndexData(0x05, data4, 1)
time.sleep(0.2)
data5 = [0x00]
_sendIndexData(0x05, data5, 1)
time.sleep(0.01)
data6 = [0x3f]
_sendIndexData(0xc2, data6, 1)
time.sleep(0.001)
data7 = [0x00]
_sendIndexData(0xd8, data7, 1) # MS_SYNC mtp_0x1d
data8 = [0x00]
_sendIndexData(0xd6, data8, 1) # BVSS mtp_0x1e
data9 = [0x10]
_sendIndexData(0xa7, data9, 1)
time.sleep(0.1)
_sendIndexData(0xa7, data5, 1)
time.sleep(0.1)
print("ss1")
data10 = [0x00, 0x01] # OSC
_sendIndexData(0x03, data10, 2) # OSC mtp_0x12
_sendIndexData(0x44, data5, 1)
data11 = [0x80]
_sendIndexData(0x45, data11, 1)
time.sleep(0.1)
_sendIndexData(0xa7, data7, 1)
time.sleep(0.1)
data12 = [0x06]
_sendIndexData(0x44, data12, 1)
data13 = [0x82]
_sendIndexData(0x45, data13, 1) # Temperature 0x82@25C
time.sleep(0.1)
time.sleep(0.1)
data14 = [0x25]
_sendIndexData(0x60, data14, 1) # TCON mtp_0x0b
data15 = [0x00] # STV_DIR
_sendIndexData(0x61, data15, 1) # STV_DIR mtp_0x1c
data16 = [0x00]
_sendIndexData(0x01, data16, 1) # DCTL mtp_0x10 ?? this is not in the flowchart
data17 = [0x00]
_sendIndexData(0x02, data17, 1) # VCOM mtp_0x11
print("ss2")
# DC-DC soft start
index51 = [0x50, 0x01, 0x0a, 0x01]
_sendIndexData(0x51, index51, 2)
index09 = [0x1f, 0x9f, 0x7f, 0xff]
for value in range(1, 5): # 1,2,3,4
_sendIndexData(0x09, index09, 1)
index51[1] = value
_sendIndexData(0x09, index09[1:], 1)
time.sleep(0.002)
for value in range(1, 11):
index51[3] = value
_sendIndexData(0x51, index51[2:], 2)
time.sleep(0.002)
for value in range(3, 11):
_sendIndexData(0x09, index09[2:], 1)
index51[3] = value
_sendIndexData(0x09, index09[3:], 1)
time.sleep(0.002)
for value in range(9, 1, -1): # 9,8,7,...2
index51[2] = value
time.sleep(0.002)
time.sleep(0.01)
def _displayRefresh():
while GPIO.input(board_EXT3.panelBusy) != GPIO.HIGH:
time.sleep(0.1)
_sendIndexData(0x15, [0x3c], 1) # Display Refresh
time.sleep(0.005)
def _DCDC_softShutdown_Mid():
time.sleep(0.1)
data19 = [0x7f]
_sendIndexData(0x09, data19, 1)
data20 = [0x7d]
_sendIndexData(0x05, data20, 1)
data55 = [0x00]
_sendIndexData(0x09, data55, 1)
time.sleep(0.2)
time.sleep(0.1)
GPIO.output(board_EXT3.panelDC, GPIO.LOW)
GPIO.output(board_EXT3.panelCS, GPIO.LOW)
GPIO.output(board_EXT3.panelCS, GPIO.HIGH) # CS# = 1
def _sendIndexData(index, data, size):
GPIO.output(board_EXT3.panelDC, GPIO.LOW) # DC Low
GPIO.output(board_EXT3.panelCS, GPIO.LOW) # (CS == CSB) Low
time.sleep(0.05)
spi.writebytes([index]) # SPI.transfer(index)
time.sleep(0.05)
GPIO.output(board_EXT3.panelCS, GPIO.HIGH) # CS High
GPIO.output(board_EXT3.panelDC, GPIO.HIGH) # DC High
GPIO.output(board_EXT3.panelCS, GPIO.LOW) # CS Low
time.sleep(0.05)
#for i in range(size):
# spi.writebytes([data[i]])
spi.writebytes(data[:size])
time.sleep(0.05)
COG_initial()
print("update")
globalUpdate(BW_monoBuffer, BW_0x00Buffer)
print("power off")
COG_powerOff()
print("program end")
What could I be doing wrong? I have SPI enabled in raspi-config, tried to run it as root, the cabling is correct (since the C code linked above works fine), triple checked everything for typos. My guess it is something trivial, e.g. RasPiArduino's SPI.transfer does something different than spidev's spi.writebytes. The only thing I see that the display does nothing and that _DCDC_softStart_Mid takes longer to execute than the C++ code.
