I am running Bullseye on an RPi 3. In attempting to run a GNURadio application I get the subject error.
During my investigation I have found several references to this issue on this and other forums.
One of the discussions led me to an FAQ on github stating the following:
"The chances are this is because ‘something’ (such as gedit) has installed mesa which added its own versions of libEGL and libGLESv2. If you run:
$ sudo find / -name libEGL*
$ sudo find / -name libGLESv2*
on the Raspberry Pi you should just get /opt/vc/lib/libEGL.so and /opt/vc/lib/libGLESv2.so if other ones turn up i.e. /usr/lib/arm-linux-gnueabihf/libEGL.so.1 you could try creating symbolic links for them all like this:
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so.1
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so $ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so.1 $ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so $ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2"
[END OF GITHUB TEXT]
When I perform the find operation I get the following:
pi@raspberrypi:~ $ sudo find / -name libGLESv2*
find: ‘/run/user/1000/doc’: Permission denied
/usr/lib/chromium-browser/swiftshader/libGLESv2.so
/usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.1.0
/opt/minecraft-pi/lib/brcm/libGLESv2.so
/opt/minecraft-pi/lib/mesa/libGLESv2.so
pi@raspberrypi:~ $ sudo find / -name libEGL*
/usr/lib/chromium-browser/swiftshader/libEGL.so
/usr/lib/arm-linux-gnueabihf/libEGL_mesa.so.0
/usr/lib/arm-linux-gnueabihf/libEGL.so.1.1.0
/usr/lib/arm-linux-gnueabihf/libEGL_mesa.so.0.0.0
/opt/minecraft-pi/lib/brcm/libEGL.so
/opt/minecraft-pi/lib/mesa/libEGL.so
As you can see I don't show the /opt/vc that the FAQ says I should see. My question is then what do I use to perform the symbolic link? Do I use minecraft-pi: either brcm or mesa? Do I use chromium-browser?
Please help as I now am completely blocked from using my GNURadio application which BTW worked well on Jessie.
Jim
Sounds like you had not enabled the GL driver and tried to do this manually. I am not sure how your modifications might affect this, but on a clean install, the GPU drivers can easily be enabled using
raspi-config
Then navigate to Advanced Options -> GL Driver -> GL (Full KMS) OpenGL desktop driver with full KMS.
After that reboot and it should work.
If you need/want you can allocate more of the system memory (RAM) to the GPU (VRAM). To do that start raspi-config again. Then navigate to Performance Options -> GPU Memory and specify the amount of GPU allocated memory. Do keep in mind that this will be consumed from the system memory, even when not in use.
sleort
  • 111
