I'm running GPSD 3.23.1 built from source but this also occurred on GPSD 3.22-4 from the debian/raspbian repositories.
When I launch any gpsd client, gpsd sends the first fix it managed to acquire, and then sends nothing else. Two fixes for this are running ubxtool -p RESET or unplugging, then replugging the gps mouse, however neither of these persist past a restart of the daemon.
The GPS mouse is not broken as it works just fine on other devices running gpsd and on gpsmon.
The only other case of this that I could find online is on this reddit thread.
OskarZyg
  • 55
I had the exact same problem and updating gpsd to version 3.25 solved the issue. I followed these instructions that I found in the comments of the Reddit thread you pointed to.
TL;DR
sudo apt install -y scons \
  libncurses-dev python-dev pps-tools git-core asciidoctor python3-matplotlib\
  build-essential manpages-dev pkg-config python3-distutils
wget http://download.savannah.gnu.org/releases/gpsd/gpsd-3.25.tar.gz tar -xzf gpsd-3.25.tar.gz cd gpsd-3.25/
sudo scons sudo scons install sudo reboot
Note: This won't setup the system's service as it would by installing gpsd with sudo apt install gpsd gpsd-clients, so you have to start it manually using: sudo gpsd --nowait --badtime --speed 9600 /dev/ttyACM0 (adjust the parameters for your setup).
smichaud
  • 126
