I managed to set up hostapd using wifi-ap via Snap so my Raspberry Pi 4 creates a new Wifi Network Ubuntu that I can connect to. When I log in to that Raspberry via SSH using the new network, I can successfully do so, and when I ping a server on the internet from within the RPI, it can reach that server.
But when I connect to the Wifi that the Pi creates from my laptop, I don't have any access to the internet.
What am I missing to "bridge" the two interfaces so I can use the Raspberry Pi as a normal access point Wifi > Ethernet?
My /etc/netplan/50-cloud-init.yaml
network:
        version: 2
        renderer: networkd
        ethernets:
                eth0:
                        dhcp4: true
                        dhcp6: true
my /var/snap/wifi-ap/361/hostapd.conf
interface=wlan0
driver=nl80211
channel=6
macaddr_acl=0
ignore_broadcast_ssid=0
ieee80211n=1
ssid=Ubuntu
auth_algs=1
utf8_ssid=1
hw_mode=g
# DTIM 3 is a good tradeoff between powersave and latency
dtim_period=3
The wmm_* options are needed to enable AMPDU
and get decent 802.11n throughput
UAPSD is for stations powersave
uapsd_advertisement_enabled=1 wmm_enabled=1 wmm_ac_bk_cwmin=4 wmm_ac_bk_cwmax=10 wmm_ac_bk_aifs=7 wmm_ac_bk_txop_limit=0 wmm_ac_bk_acm=0 wmm_ac_be_aifs=3 wmm_ac_be_cwmin=4 wmm_ac_be_cwmax=10 wmm_ac_be_txop_limit=0 wmm_ac_be_acm=0 wmm_ac_vi_aifs=2 wmm_ac_vi_cwmin=3 wmm_ac_vi_cwmax=4 wmm_ac_vi_txop_limit=94 wmm_ac_vi_acm=0 wmm_ac_vo_aifs=2 wmm_ac_vo_cwmin=2 wmm_ac_vo_cwmax=3 wmm_ac_vo_txop_limit=47 wmm_ac_vo_acm=0
Regulatory domain options
Country code set to global
country_code=XX
End reg domain options
wpa=2 wpa_key_mgmt=WPA-PSK wpa_passphrase=***************** wpa_pairwise=TKIP rsn_pairwise=CCMP
my netconfig output
ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:c4:76:07:d8  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.8.104 netmask 255.255.255.0 broadcast 192.168.8.255 inet6 fe80::dea6:32ff:fe0d:47b2 prefixlen 64 scopeid 0x20<link> inet6 fd29:d2c5:be9d::d60 prefixlen 128 scopeid 0x0<global> inet6 fd29:d2c5:be9d:0:dea6:32ff:fe0d:47b2 prefixlen 64 scopeid 0x0<global> ether dc:a6:32:0d:47:b2 txqueuelen 1000 (Ethernet) RX packets 9251 bytes 3761308 (3.7 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 7765 bytes 1113458 (1.1 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 23558 bytes 3709615 (3.7 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 23558 bytes 3709615 (3.7 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.0.60.1 netmask 255.255.255.0 broadcast 0.0.0.0 ether dc:a6:32:0d:47:b3 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 102 bytes 82620 (82.6 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ChrisB
  • 109
It seems I've found the answer!
Just unmask:
systemctl unmask hostapd
then
systemctl enable hostapd
And restart.
I hope it works for you, too.
ChrisB
  • 109
