I have a question on the interaction between Pi Pico, CircuitPython, and USB. I need a way to send a data stream from the Pico to another computer where it will be received on a USB port (it's the only possible input port). Do I assume correctly that I cannot use the Pico's USB port for that, because it is already used by CircuitPython for its file system and/or REPL? Does that mean that in order to develop with CircuitPython, I would have to send the data on UART instead and use a TTL-to-USB converter?
0__
  • 522
You can do it via USB HID, re. the Pico works as a Keyboard, sending data to a connected computer.
Annie
  • 26
You can also communicate with host via USB serial device - a better choice for sensor data perhaps; this works in in C from pico so should be possible with circuit python
jxb
It works with the two USB ports that CircuitPython supports. And it works on all devices listed on this page, where the Pico is one of them: usb_cdc – USB CDC Serial streams
You get the list of supported devices by expanding the triangle "Available on these boards".
Microsoft Windows:
The prerequisite is a flawless installation of drivers on the PC. I had an issue with Windows 7 which installs only one serial port - the console port. Windows 10 seems to be the minimum OS version.
Then add two lines in boot.py:
import usb_cdc
usb_cdc.enable(console=True, data=True)
The 2nd serial port becomes visible in Device Manager as soon as connect your board with your new boot.py
