I'm using a usb to ethernet with my Raspberry Zero W but it doesn't get any IP (usb0 interface):
rogermiranda1000@raspberrypi:~ $ ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 36:33:e3:ba:6f:72 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.3.123 netmask 255.255.255.0 broadcast 192.168.3.255 inet6 fe80::ba27:ebff:fe45:e9e5 prefixlen 64 scopeid 0x20<link> ether b8:27:eb:45:e9:e5 txqueuelen 1000 (Ethernet) RX packets 380 bytes 47826 (46.7 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 155 bytes 22392 (21.8 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
On /etc/network/interfaces I have this:
auto usb0 iface usb0 inet dhcp
auto wlan0 allow-hotplug wlan0 iface wlan0 inet dhcp wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
If I use ifup here's the output:
rogermiranda1000@raspberrypi:~ $ sudo ifup usb0
Internet Systems Consortium DHCP Client 4.4.1
Copyright 2004-2018 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/usb0/36:33:e3:ba:6f:72 Sending on LPF/usb0/36:33:e3:ba:6f:72 Sending on Socket/fallback DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 4 DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 11 DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 12 DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 10 DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 15 DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 9 No DHCPOFFERS received. No working leases in persistent database - sleeping.
If it's useful, here's dmesg output:
rogermiranda1000@raspberrypi:~ $ dmesg | grep usb0
[    8.421372] usb0: HOST MAC 32:f0:31:6c:f5:94
[    8.424389] usb0: MAC 36:33:e3:ba:6f:72
I have also tried to configure a static IP. In that case the IP is OK, but I couldn't ping the device.
Edit:
ethtool result (but according to the product description it's a "driver-free adapter"):
rogermiranda1000@raspberrypi:~ $ sudo ethtool -i usb0
driver: g_ether
version: 29-May-2008
firmware-version: 20980000.usb
expansion-rom-version:
bus-info: gadget
supports-statistics: no
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
ip result:
rogermiranda1000@raspberrypi:~ $ ip a && ip r
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group defaul        t qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
2: usb0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen        1000
    link/ether fe:eb:bb:8e:64:77 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP g        roup default qlen 1000
    link/ether b8:27:eb:45:e9:e5 brd ff:ff:ff:ff:ff:ff
    inet 192.168.3.123/24 brd 192.168.3.255 scope global dynamic wlan0
       valid_lft 43160sec preferred_lft 43160sec
    inet6 fe80::ba27:ebff:fe45:e9e5/64 scope link
default via 192.168.3.1 dev wlan0
192.168.3.0/24 dev wlan0 proto kernel scope link src 192.168.3.123
I am continually amazed by the things people put into /etc/network/interfaces.
It hasn't been used by Raspberry Pi OS for 7 years, and what you have would not have been correct even then!
Your /etc/network/interfaces will disable the default dhcpcd networking. Either delete your changes or just delete /etc/network/interfaces (which by default does NOTHING).
See How to set up networking/WiFi
This may not fix your problem, but it won't make it any worse. If it still doesn't work post the output of ip a && ip r
Your question mentions g_ether, but this should not be necessary for a USB Ethernet dongle. It is possible you have made other changes, but not elaborated.
