I am running ruby 3.0.3 on Raspbian 11 on raspberry pi 4b and I am trying to use adc mcp3008 using pi_piper gem and whenever I initialize a pin clock = PiPiper::Pin.new :pin => 18, :direction => :out I get bcm2835_init: gpio mmap failed: Cannot allocate memory error with full memory dump
I know a lot of people are doing ruby with Raspberry PI, which is a shame, but if anyone out there has any hits it be great.
Full dump:
irb(main):003:0> clock = PiPiper::Pin.new :pin => 18, :direction => :out
/root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb:120: [BUG] Segmentation fault at 0x00000093
ruby 3.0.3p157 (2021-11-24 revision 3fb7d2cadc) [armv7l-linux-eabihf]
-- Control frame information -----------------------------------------------
c:0025 p:---- s:0127 e:000126 CFUNC :pin_set_pud
c:0024 p:0136 s:0121 e:000120 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb:120
c:0023 p:0234 s:0116 e:000115 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb:60 [FINISH]
c:0022 p:---- s:0111 e:000110 CFUNC :new
c:0021 p:0019 s:0106 E:0011e4 EVAL (irb):3 [FINISH]
c:0020 p:---- s:0102 e:000101 CFUNC :eval
c:0019 p:0020 s:0094 e:000093 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/workspace.rb:116
c:0018 p:0059 s:0086 e:000084 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/context.rb:450
c:0017 p:0163 s:0077 e:000076 BLOCK /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:567
c:0016 p:0024 s:0072 e:000071 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:751
c:0015 p:0007 s:0066 e:000065 BLOCK /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:548
c:0014 p:0123 s:0061 e:000060 BLOCK /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:251 [FINISH]
c:0013 p:---- s:0057 e:000056 CFUNC :loop
c:0012 p:0005 s:0053 e:000052 BLOCK /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:233 [FINISH]
c:0011 p:---- s:0050 e:000049 CFUNC :catch
c:0010 p:0010 s:0045 e:000044 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:232
c:0009 p:0046 s:0041 E:0012fc METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:547
c:0008 p:0004 s:0036 e:000035 BLOCK /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:481 [FINISH]
c:0007 p:---- s:0033 e:000032 CFUNC :catch
c:0006 p:0058 s:0028 E:001228 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:480
c:0005 p:0104 s:0022 e:000021 METHOD /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:409
c:0004 p:0019 s:0016 e:000015 TOP /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/irb-1.3.5/exe/irb:11 [FINISH]
c:0003 p:---- s:0013 e:000012 CFUNC :load
c:0002 p:0112 s:0008 E:002660 EVAL /root/.rbenv/versions/3.0.3/bin/irb:23 [FINISH]
c:0001 p:0000 s:0003 E:0013d0 (none) [FINISH]
-- Ruby level backtrace information ----------------------------------------
/root/.rbenv/versions/3.0.3/bin/irb:23:in <main>' /root/.rbenv/versions/3.0.3/bin/irb:23:inload'
/root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/irb-1.3.5/exe/irb:11:in <top (required)>' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:409:instart'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:480:in run' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:480:incatch'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:481:in block in run' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:547:ineval_input'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:232:in each_top_level_statement' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:232:incatch'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:233:in block in each_top_level_statement' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:233:inloop'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb:251:in block (2 levels) in each_top_level_statement' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:548:inblock in eval_input'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:751:in signal_status' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb:567:inblock (2 levels) in eval_input'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/context.rb:450:in evaluate' /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/workspace.rb:116:inevaluate'
/root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/workspace.rb:116:in eval' (irb):3:in<main>'
(irb):3:in new' /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb:60:ininitialize'
/root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb:120:in pull!' /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb:120:inpin_set_pud'
-- Machine register context ------------------------------------------------
"r0: 0x00000093 "r1: 0x00000000 "r2: 0x00000000 "r3: 0x00000000 "r4: 0x00000012
"r5: 0xb3f22a58 "r6: 0x00000002 "r7: 0x00e44c1c "r8: 0x00000002 "r9: 0xbec59088
"r1: 0xbec5908c "sp: 0xbec59088 "fa: 0x00000093
-- Other runtime information -----------------------------------------------
Loaded script: irb
Loaded features:
0 enumerator.so
1 thread.rb
2 rational.so
3 complex.so
4 ruby2_keywords.rb
5 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/enc/encdb.so
6 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/enc/trans/transdb.so
7 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/rbconfig.rb
8 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/compatibility.rb
9 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/defaults.rb
10 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/deprecate.rb
11 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/errors.rb
12 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/exceptions.rb
13 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/basic_specification.rb
14 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/stub_specification.rb
15 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/text.rb
16 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/user_interaction.rb
17 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/specification_policy.rb
18 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/util/list.rb
19 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/platform.rb
20 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/version.rb
21 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/requirement.rb
22 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/specification.rb
23 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/util.rb
24 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/dependency.rb
25 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/core_ext/kernel_gem.rb
26 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/monitor.so
27 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/monitor.rb
28 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/core_ext/kernel_require.rb
29 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/core_ext/kernel_warn.rb
30 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/path_support.rb
31 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/bundler_version_finder.rb
32 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems.rb
33 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/version.rb
34 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/core_ext/name_error.rb
35 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/levenshtein.rb
36 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/jaro_winkler.rb
37 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checker.rb
38 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/name_error_checkers/class_name_checker.rb
39 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/name_error_checkers/variable_name_checker.rb
40 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/name_error_checkers.rb
41 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/method_name_checker.rb
42 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/key_error_checker.rb
43 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/null_checker.rb
44 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/tree_spell_checker.rb
45 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/spell_checkers/require_path_checker.rb
46 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean/formatters/plain_formatter.rb
47 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/did_you_mean.rb
48 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/tsort/lib/tsort.rb
49 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/tsort.rb
50 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/request_set/gem_dependency_api.rb
51 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/request_set/lockfile/parser.rb
52 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/request_set/lockfile/tokenizer.rb
53 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/request_set/lockfile.rb
54 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/request_set.rb
55 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/gem_metadata.rb
56 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/delegates/specification_provider.rb
57 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/errors.rb
58 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/action.rb
59 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/add_edge_no_circular.rb
60 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/add_vertex.rb
61 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/delete_edge.rb
62 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/detach_vertex_named.rb
63 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/set_payload.rb
64 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/tag.rb
65 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/log.rb
66 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph/vertex.rb
67 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/dependency_graph.rb
68 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/state.rb
69 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/modules/specification_provider.rb
70 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/delegates/resolution_state.rb
71 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/resolution.rb
72 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/resolver.rb
73 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo/modules/ui.rb
74 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo/lib/molinillo.rb
75 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/molinillo.rb
76 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/activation_request.rb
77 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/conflict.rb
78 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/dependency_request.rb
79 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/requirement_list.rb
80 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/stats.rb
81 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/set.rb
82 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/api_set.rb
83 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/composed_set.rb
84 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/best_set.rb
85 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/current_set.rb
86 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/git_set.rb
87 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/index_set.rb
88 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/installer_set.rb
89 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/lock_set.rb
90 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/vendor_set.rb
91 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/source_set.rb
92 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/specification.rb
93 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/spec_specification.rb
94 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/api_specification.rb
95 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/git_specification.rb
96 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/index_specification.rb
97 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/installed_specification.rb
98 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/local_specification.rb
99 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/lock_specification.rb
100 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver/vendor_specification.rb
101 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/resolver.rb
102 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source/git.rb
103 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source/installed.rb
104 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source/specific_file.rb
105 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source/local.rb
106 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source/lock.rb
107 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source/vendor.rb
108 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/rubygems/source.rb
109 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/set.rb
110 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/ripper.so
111 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/ripper/core.rb
112 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/ripper/lexer.rb
113 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/ripper/filter.rb
114 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/ripper/sexp.rb
115 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/ripper.rb
116 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/io/console.so
117 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/timeout.rb
118 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/forwardable/impl.rb
119 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/forwardable.rb
120 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/version.rb
121 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/config.rb
122 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/key_actor/base.rb
123 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/key_actor/emacs.rb
124 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/key_actor/vi_command.rb
125 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/key_actor/vi_insert.rb
126 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/key_actor.rb
127 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/key_stroke.rb
128 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/kill_ring.rb
129 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/unicode/east_asian_width.rb
130 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/unicode.rb
131 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/delegate.rb
132 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/fileutils.rb
133 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/etc.so
134 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/tmpdir.rb
135 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/tempfile.rb
136 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/line_editor.rb
137 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/history.rb
138 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/ansi.rb
139 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline/general_io.rb
140 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/reline.rb
141 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/init.rb
142 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/workspace.rb
143 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/inspector.rb
144 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/src_encoding.rb
145 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/magic-file.rb
146 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ruby-lex.rb
147 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/completion.rb
148 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/input-method.rb
149 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/output-method.rb
150 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/context.rb
151 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/extend-command.rb
152 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/locale.rb
153 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/color.rb
154 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/version.rb
155 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/easter-egg.rb
156 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb.rb
157 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/prettyprint.rb
158 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/pp.rb
159 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/color_printer.rb
160 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/irb/ext/save-history.rb
161 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/enc/trans/single_byte.so
162 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/rubyeventmachine.so
163 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/version.rb
164 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/pool.rb
165 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/deferrable.rb
166 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/future.rb
167 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/streamer.rb
168 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/spawnable.rb
169 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/processes.rb
170 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/iterator.rb
171 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/buftok.rb
172 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/timers.rb
173 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/protocols.rb
174 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/connection.rb
175 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/callback.rb
176 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/queue.rb
177 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/channel.rb
178 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/file_watch.rb
179 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/process_watch.rb
180 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/tick_loop.rb
181 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/resolver.rb
182 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/completion.rb
183 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/em/threaded_resource.rb
184 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/shellwords.rb
185 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/socket.so
186 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/armv7l-linux-eabihf/io/wait.so
187 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/socket.rb
188 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/securerandom.rb
189 /root/.rbenv/versions/3.0.3/lib/ruby/3.0.0/resolv.rb
190 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/eventmachine-1.0.9/lib/eventmachine.rb
191 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/frequency.rb
192 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/i2c.rb
193 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin_values.rb
194 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin.rb
195 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pin_error.rb
196 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/platform.rb
197 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/pwm.rb
198 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/spi.rb
199 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/stub_driver.rb
200 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/version.rb
201 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper.rb
202 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi_c.so
203 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/platform.rb
204 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/data_converter.rb
205 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/types.rb
206 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/library.rb
207 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/errno.rb
208 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/abstract_memory.rb
209 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/pointer.rb
210 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/memorypointer.rb
211 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/struct_layout.rb
212 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/struct_layout_builder.rb
213 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/struct_by_reference.rb
214 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/struct.rb
215 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/union.rb
216 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/managedstruct.rb
217 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/callback.rb
218 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/io.rb
219 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/autopointer.rb
220 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/variadic.rb
221 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/enum.rb
222 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/version.rb
223 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi/ffi.rb
224 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/ffi-1.15.4/lib/ffi.rb
225 /root/.rbenv/versions/3.0.3/lib/ruby/gems/3.0.0/gems/pi_piper-2.0.0/lib/pi_piper/bcm2835.rb
Aborted
