My raspberry pi zero ran out of space on its microSD card and somehow corrupted part of the filesystem, as it doesn't boot properly. When I insert the microSD card into another computer, I can look at the /etc/fstab file and it looks like this:
PARTUUID=d271c287-01  /boot           vfat    defaults          0       2
PARTUUID=d271c287-02  /               ext4    defaults,noatime  0       1
(Yes, the weird sequence at the bottom is not a mistake - it's what the file looks like). I'm imagining that maybe I can just delete this line and everything will work as normal? I was also thinking that this could maybe due to an odd interpretation of a slightly different charset by my computer, as I've never seen this kind of pattern before.
lriley
It may be that your SD card is having issues - they are subject to wear-out, and the cheaper ones die younger than (for example) SD cards made by SanDisk.
You should edit /etc/fstab to remove the bogus entry, but keep an eye out for other strange behavior. You should also consider making a backup of your system so that you can recover your system if it fails catastrophically. Here's one way to do that using image-backup
Seamus
  • 23,558
  • 83
I'd be tempted to manually remove the spurious line from /etc/fstab, mount the microSD card on a Linux box (or PC running a live Linux distro), and check the filesystem of each partition with fsck before attempting to boot from it again
