In order to clarify my question -
cat /proc/device-tree/model:
Raspberry Pi 3 Model B Rev 1.2
cat /etc/os-release:
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
apache2 -v:
Server version: Apache/2.4.51 (Raspbian)
Server built:   2021-10-07T17:49:44
mysql -V:
mysql  Ver 15.1 Distrib 10.5.12-MariaDB, for debian-linux-gnueabihf (armv7l) using  EditLine wrapper
ip r | grep default:
default via 192.168.1.254 dev wlan0 proto dhcp src 192.168.1.76 metric 303
sudo nano /etc/resolv.conf:
# Generated by resolvconf
nameserver 192.168.1.254
I hope I have generated the necessary information you need to assist me. I am new to this, so I looked-up those commands. I have two SD cards, but only one Raspberry Pi 3. Above is what I have installed on one SD card. The issue I'm having is I have another SD card that I plan on using - installing the same above, but when I go to install everything - then the IP address is still the same:
192.168.1.76
I am wanting the second SD card to be something like:
192.168.1.46
So, when I swap out the SD cards, then the local IP address is already changed. Is this even possible?
Thank you for your time.
EDIT:
ip a && ip r:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether b8:27:eb:82:72:4d brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:d7:27:18 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.76/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
       valid_lft 56330sec preferred_lft 45530sec
    inet6 2600:1700:3b01:2a70:b648:20cf:994:626/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 3208sec preferred_lft 3208sec
    inet6 fe80::cdc9:5bc:9b4e:7f4b/64 scope link
192.168.1.0/24 dev wlan0 proto dhcp scope link src 192.168.1.76 metric 303
Sanders
What you want is possible and quite simple.
Include the following in /etc/dhcpcd.conf
interface wlan0
request 192.168.1.76
See Setup a Static IP Address in How to set up networking/WiFi for detail.
(Most Pi users go to some lengths to ensure that each Pi has a unique address, so this is unusual and I wonder WHY?)
NOTE you will get suggestions to use a Static IP Address; this is commonly (and inappropriately) suggested on the Pi, but the simple rule is if you have a router on your network do not set a Static IP Address.
Typically the IP address is assigned from a DHCP server. The DHCP server looks at your hardware's ethernet address (listed after link/ether in ip addr output and gives each one a (temporary) unique IP address.
Each Pi and each network interface should have unique ethernet addresses assigned by the manufacturer.
So it is OK for different SD cards to get the same IP, because by default the IP is associated with the Pi hardware, not the SD card.
On the other hand, if you need to externally determine which SD card was booted, it might make sense to force the IP address to be associated with the SD card rather than the Pi hardware. But this would be a special case.
user10489
  • 1,001
