I recently created a Windows 11 Pro ARM64 .iso through uupdump.net aria2c to .iso conversion everything went fine the .iso was made i then launched WoR (Windows on Raspberry) everything was done correctly i used the default option apart that i selected wimlib as the install and choose to use lzx compression, my Raspberry Pi is the 4B model the eeprom was updated to usb-boot, it is the model with 4Gb of ram, i am also using a 64Gb Kingston 3.0 usb, once it installed correctly i ejected the usb from my pc, Then i plugged into the Rapberry Pi, plugged in ethernet, plugged in my keyboard, connected it to my monitor and then plugged it into the power outlet, it booted up fine via the usb 3.0 port, i ajusted the setting, display: 720p, ram: use all ram. saved, exited BIOS, pressed enter to boot, then it just kept on the boot screen for 10 mins, then it started verbosing, it just said two lines: no internet connection detected, no internet connection detected, and stayed like that on the boot screen. Am i missing any steps on how to do this? Or is this a common issue? Edit: I tried rebooting several times, after two reboots it finally just gave the rainbow screen.
Asked
Active
Viewed 1,307 times
Booting Windows on Raspberry Pi is not fast enough compared to PCs, but some options can help you anyway:
- Use fast 100 MB/s U3 Class 10 SD card (like SiliconPower Superior Pro)
- Change the boot order in the boot option to disable the UEFI ethernet check.
- Be a little bit patient :)
And for better performance:
Disable transparent effect in windows.
Change the performance option : Right-click on This PC > Properties > Advanced system setting > Performance > setting > Adjudt for best performance
Install IoT Enterprise version that is lighter than the Pro version.
Pouya
- 55
- 1
- 11
