This isn't necessarily a Pi-specific question, but might be applicable to general Linux. However, my hunch is that the Pi's uniqueness might have something to do with it.
I'm trying to run two scripts on startup on my Pi 4 (raspbian stretch).
One is a python 2 script (I have Python 2 and 3 installed on the Pi, but Python2.7 is run when you simply do python script.py), the other is a CLI app based on a python 3 module installed via pip3, midiroute. EDIT: The purpose of running both of these scripts at startup: 1) to start the samplerbox script , and 2) to loopback incoming midi from an attached Midi keyboard (native instruments komplete kontrol) back to its 5-pin output, if the keyboard is connected and listed as a midi device. Context: this allows me to control hardware connected via 5-pin midi as well as the software instrument that is samplerbox.
I remember having this issue before (in a different context, on an Ubuntu server), so I tried to find the full paths to the binaries that execute these scripts using
which python
which midiroute
This returns the full paths.
I then put these full paths into either crontab or a new .service file. However, when aiming to run them on startup, neither work.
The py script tells me it's missing a required module (which it isn't if i simply start the script using python script.py), like so:
File "/home/pi/SamplerBox/samplerbox.py", line 27, in <module>
import samplerbox_audio # audio-module (cython)
File "samplerbox_audio.pyx", line 51, in init samplerbox_audio
import gv
ImportError: No module named gv
The other job logs an error that it can't find the required binary, like so: /home/pi/nl_utils/midi_redirect_kompletekontrol.sh: 7: /home/pi/nl_utils/midi_redirect_kompletekontrol.sh: midiroute: not found
any ideas as to how I can do this?
EDIT:
my crontab:
@reboot /usr/bin/python /home/pi/SamplerBox/samplerbox.py > /home/pi/nl_utils/logfiles/samplerbox.log 2>&1
@reboot sh /home/pi/nl_utils/midi_redirect_kompletekontrol.sh > /home/pi/nl_utils/logfiles/midi_route.log 2>&1
my .service:
pi@raspberrypi:/etc/systemd/system $ cat run_midi_routing_at_startup.service
[Unit]
Description=Run the midi routing script after startup once all other startup daemons have loaded.
After=default.target
[Service]
Type=simple
RemainAfterExit=yes
ExecStart=/home/pi/nl_utils/midi_redirect_kompletekontrol.sh
TimeoutStartSec=0
[Install]
WantedBy=default.target
