My Pi is configured with Arch to use eth0 with a static IP configured in conf.d:
[gotschi@berry ~]$ cat /etc/conf.d/network@eth0
address=10.0.55.5
netmask=24
broadcast=10.0.55.255
gateway=10.0.55.254
This worked better than any other configuration (e.g. netctl) for me since a few weeks. The only weird thing: It uses 2 IP addresses. When I scan my Network Range my Pi shows up 2 Times: One with the static IP of 10.0.55.5 and the other was assigned by my DHCP I assume (Range set on router: 10.0.55.50-150): 10.0.55.55
nmap also reports the hostname only on the .55 address, so http://raspberry.local/ is assigned to .55
my /etc/netctl folder is empty, except for the default folders...
[gotschi@berry ~]$ ls /etc/netctl
    examples  hooks  interfaces
It also responds to 10.0.55.55 correctly!
Where are other configs stored? Thanks!
[gotschi@berry ~]$ ifconfig
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 10.0.55.5  netmask 255.255.255.0  broadcast 10.0.55.255
    ether b8:27:eb:50:ec:f4  txqueuelen 1000  (Ethernet)
    RX packets 17227  bytes 1077447 (1.0 MiB)
    TX packets 85328  bytes 127324380 (121.4 MiB)
edit I think I found something here:
[gotschi@berry ~]$ ip addr
    4: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:50:ec:f4 brd ff:ff:ff:ff:ff:ff
inet 10.0.55.5/24 brd 10.0.55.255 scope global eth0
inet 10.0.55.55/24 brd 10.0.55.255 scope global secondary eth0
sudo ip addr del 10.0.55.55/24 dev eth0 disabled the second IP, just trying a reboot now
-> nope, still got 2 ip addresses :/
bfrgzju
  • 191
Gotschi
  • 608
5 Answers5
This helped for me:
update-rc.d dhcpcd disable
service dhcpcd stop
ip addr del %YOURS-SECOND-IP% dev ethX
And when you start raspberry pi again, scope global secondary will disappear.
DeamonMV
  • 196
Edit /etc/dhcpcd.conf
This happened to me too (albiet on Raspbian).
If you'd rather not totally disable the dhcpcd service, you can add this to /etc/dhcpcd.conf to inform it of your static interface:
interface eth0
static ip_address=192.168.0.10/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1 8.8.8.8
This will stop it from grabbing a secondary ip upon rebooting.
(ArchWiki Reference)
Hydraxan14
  • 1,876
The issue was caused by a separate dhcp@network laying in /etc/systemd/system/
No clue where it came from, but deleting it solved my problem :)
Gotschi
  • 608
On Raspbian, I found that this situation arose from having the GUI Network Manager running while the dhcpcd service is also running. sudo systemctl mask dhcpcd and a subsequent reboot took care of it.
It is getting a DHCP IP from dhcpcd.conf and using your netplan - you can run both, I learned the hard way, I think you can even assign different IP ranges and all work - here's the trick, disable DHCP (and for fun you can rename your conf file - but - with no conf file, if DHCP is still running it will auto-use DHCP and you'll see the ip in ip a.)
systemctl stop dhcpcd
systemctl disable dhcpcd
1coolbox
