This is on a system upgraded from Buster to Bullseye. Ethernet works fine, but WiFi cannot scan for available networks with "No carrier" error message:
pi@raspberrypi:~ $ connmanctl enable wifi
Error wifi: Already enabled
pi@raspberrypi:~ $ connmanctl scan wifi
Error /net/connman/technology/wifi: No carrier
I can see that wlan0 is there, not blocked by rfkill and wpa_supplicant is running.
pi@raspberrypi:~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
pi@raspberrypi:~ $ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
pi@raspberrypi:~ $ systemctl status 579
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-11-19 16:40:15 CET; 24h ago
Process: 429 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
Main PID: 489 (dhcpcd)
Tasks: 2 (limit: 4915)
CPU: 34.626s
CGroup: /system.slice/dhcpcd.service
├─489 /sbin/dhcpcd -q -b
└─579 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
Is there anything else I should check? Or is connmanctl not supposed to work on Bullseye?
@Milliways, connman appears to be installed as a dependency of lxde, which is what I have for desktop on the Pi:
pi@raspberrypi:~ $ apt-cache --installed rdepends connman-gtk
connman-gtk
Reverse Depends:
|lxde
