How do I install GDM and any other necessary packages for it to run on the Raspbian image?
The Pi doesn't have very powerful hardware. GDM will have heaps of Gnome dependencies. It might be better to look for a lighter weight login manager. SLIM might be a good choice (I think Raspbian is using it). Otherwise LightDM is what Ubuntu uses.
- 181
- 3
Assuming you just want to install GDM, and not an actual window manager, just run.
$ sudo apt-get install gdm
This would be strange though as GDM is a display manager. A display manager only provides the equivalent of a login prompt. In order to actually use your desktop you would need to install a window manager, such as GNOME or Xfce.
So, just in case you would like to also install a window manager then you need to do the following.
First, you need to make sure you have
taskselandaptitude. You can install these on Debian-derived systems viaapt-get.$ sudo apt-get install aptitude taskselNow you need to install the GNOME task via
tasksel.$ sudo tasksel install gnome-desktop --new-install
- 15
- 69
- 113
