I really like timeshift for backup and restore because it's simple, works well, and I can store the backup locally. I have not been able to get it to work on a pi though. When installed from apt this I get this error when I try to make a backup:
sudo timeshift --create --comments "init" --debug
D: Main()
D:
D: Running Timeshift v19.01
D:
D: Session log file: /var/log/timeshift/2021-10-25_06-03-26_ondemand.log
D: Distribution: raspbian "10"
D: DIST_ID: raspbian
D: Main: check_dependencies()
D: Main: add_default_exclude_entries()
D: Main: add_default_exclude_entries(): exit
D: update_partitions()
D: df -T -B1
D: Device: get_disk_space_using_df(): 1
D: Device: get_mounted_filesystems_using_mtab(): 1
D: Device: get_filesystems(): 5
D: partition list updated
D: detect_system_devices()
D: /boot is mapped to device: /dev/mmcblk0p1, UUID=5DE4-665C
D: / is mapped to device: /dev/mmcblk0p2, UUID=7295bbc3-bbc2-4267-9fa0-099e10ef5bf0
D: Searching subvolume for system at path: /
D: Users: root pi
D: Encrypted home users:
D: Encrypted home dirs:
D: Encrypted private dirs:
D: Main: load_app_config()
App config loaded: /etc/timeshift.json
D: IconManager: init()
D: bin_path: /usr/bin/timeshift
D: found images directory: /usr/share/timeshift/images
D: Main(): ok
D: AppConsole: parse_arguments()
D: Main: initialize_repo()
D: backup_uuid=
D: backup_parent_uuid=
D: Setting snapshot device from config file
D: Main: initialize_repo(): exit
D: AppConsole: start_application()
Select backup device:
Num Device Size Type Label
0 > /dev/mmcblk0p2 31.7 GB ext4 rootfs
Enter device name or number (a=Abort): ^[[A
E: Invalid input
Enter device name or number (a=Abort): 0
D: SnapshotRepo: from_device(): RSYNC
D: SnapshotRepo: init_from_device()
D:
D: SnapshotRepo: unlock_and_mount_devices()
D: device=/dev/mmcblk0p2
D: SnapshotRepo: unlock_and_mount_device()
D: udisksctl mount -b '/dev/mmcblk0p2'
Error mounting /dev/mmcblk0p2: GDBus.Error:org.freedesktop.UDisks2.Error.AlreadyMounted: Device /dev/mmcblk0p2 is already mounted at `/'.
D: Selected snapshot device: /dev/mmcblk0p2
D: Free space: 0 B
D: SnapshotRepo: check_status()
D: SnapshotRepo: available()
D: is_available: ok
D: SnapshotRepo: has_snapshots()
D: SnapshotRepo: has_space()
D: df -T -B1 '/dev/mmcblk0p2'
D: Device: get_disk_space_using_df(): 0
D: no snapshots
D: SnapshotRepo: check_status(): exit
D: SnapshotRepo: init_from_device(): exit
D: is_available: ok
D: Main: create_snapshot()
D: no snapshots
E: Not enough disk space (< 1.4 GB)
E: Select another device or free up some space
D: SnapshotRepo: auto_remove()
D: SnapshotRepo: remove_untagged()
D: SnapshotRepo: load_snapshots()
D: loading snapshots from 'timeshift/snapshots': 0 found
D: no snapshots
D: exit_app()
D: crontab -l
D: Failed to read cron tab
D: crontab -l
D: unmount_target_device()
D: clean_logs()
D: rm -rf '/tmp/2ol7sJPh'
if it helps, the output of df -T -B1 '/dev/mmcblk0p2' is
Filesystem Type 1B-blocks Used Available Use% Mounted on
devtmpfs devtmpfs 450473984 0 450473984 0% /dev
I'd like to figure out how to get timeshift to work, but suggestions for a similar alternative are also welcome.
