I am writing a bash script and I really want a way to detect if the user has booted from a microSD card versus an external SSD drive connected via USB. Ideally, this should work with any PI3/4. I am not that familiar with how linux drives are named/labelled. Currently, I am booting my Pi from USB SSD on my Pi4, and lsblk, reports that sda1 contains the firmware, and sda2 the main partition. Can I assume that sda will always be an external USB drive, or will microSD cards use sda as well? If not, what is the best way to tell them apart? Ideally, I would prefer to use a built-in Linux command to establish this (if possible) so my script doesn't need to install any new packages. Thanks in advance.
How generic does your script need to be? Are you going to support non-standard partition configurations, encrypted partitions, overlays, LVM and such? If not, you can trivially run
`mount | grep 'on / '| cut -d' ' -f1`
This will substitute to /dev/mmcblk0p2 (in general, /dev/mmcblk0pX) if you boot from the built-in SD card reader, or /dev/sda2 (in general, /dev/sdXY) if you boot from a USB storage, be it an SD card in a USB card reader, an SSD or an HDD. I think the current Pi bootloader will fail to boot from anything but sda anyway.
You can do the same with lsblk if you prefer:
`lsblk -o pkname,mountpoint | egrep '/$' | cut -d' ' -f1`
This returns either mmcblk0 or sda, which is perhaps easier to parse.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
