I am trying to use the second serial port. In /boot/config.txt I have put at the end :
# swap UARTs
dtoverlay=pi3-miniuart-bt
dtoverlay=uart2
enable_uart=1
I have checked and re-checked the pin connections. Uart 2 is on GPIO 0 and 3. Still cant receive anything from an arduino on the other side. Is there some configuration missing ?
dlsa
  • 111
I use the following settings:
dtoverlay=uart2
dtoverlay=uart3
dtoverlay=pi3-miniuart-bt enable_uart=1
They give access to uart2 (on GPIO 0 and 1) and uart3 (on GPIO 4 and 5). Bluetooth works, and the default UART on GPIO 14 and 15 is available as well.
PMF
  • 906
The BCM2711 has 6 UART (of which 4 are usable on the Pi4).
See How do I make serial work on the Raspberry Pi3 or later
Raspberry Pi4 UART
I was struggling with getting serial ports to work on Bookworm and my Pi4 for a few hours. I found a thread somewhere that someone said they used "sudo dtoverlay uart2" to get things to show up properly. Notice there is no "="? I changed my /boot/firmware/config.txt to this to get things working:
dtoverlay uart2
dtoverlay uart3
dtoverlay uart4
NO "="!
Maybe a bug?
Hope this helps someone that struggled like I did.
