I have a brand new Compute Module 4 with Raspberry Pi OS installed. The system is up-to-date, but I cannot read GPIOs or change their state.
$ gpio -v
gpio version: 2.52
Copyright (c) 2012-2018 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details: Type: (null), Revision: 00, Memory: 4096MB, Maker: Sony
  • Device tree is enabled.
*--> Raspberry Pi Compute Module 4 Rev 1.0
  • This Raspberry Pi supports user-level GPIO access.
If I try to read all gpios I get this error:
$ gpio readall
Oops - unable to determine board type... model: 20
If I try to change the state of a GPIO it doesn't work
$ gpio mode 13 out
$ gpio write 13 1
However it does work with the following:
echo "13" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio13/direction
echo "1" > /sys/class/gpio/gpio13/value
What would be the correct way of using GPIOs on the CM4?
nowox
  • 239
"What would be the correct way of using GPIOs on the CM4?"
This is strictly opinion based, and thus off topic.
The strict (Linux kernel purist) answer is to use gpiochip interface. Unfortunately this currently provides limited functionality and is a little tardy.
Linux kernel purists consider ANY method of accessing hardware which bypasses the kernel incorrect.
All of the current Pi libraries directly access hardware for performance/functionality. (Joan's lg library is a possible exception.)
See Controlling Raspberry Pi GPIO with c and Python
As others have pointed out WiringPi is deprecated, and has no support for CM4; support for Pi4 is limited and incomplete.
However if you want a gpio readall equivalent you could try GPIOreadall
You would probably be better served by using my lg archive of programs. C and Python are supported.
The archive uses the new /dev/gpiochip interface rather than the deprecated sysfs interface used by wiringPi and RPi.GPIO.
lg also has the advantage of being a generic Linux archive and is not tied to the Raspberry Pi.
joan
  • 71,852
  • 76
  • 108
That gpio utility is part of WiringPi which was deprecated.
There is an unofficial mirror: https://github.com/WiringPi
Are you planning on developing something in a language such as Python or C ?
I use the RPi.GPIO library in Python: https://sourceforge.net/p/raspberry-gpio-python/wiki/BasicUsage/
Another Python library gpiozero simplifies things even more: https://gpiozero.readthedocs.io/en/stable/
CoderMike
  • 7,102
In my experience (up to & including the buster release), gpio works fine on the RPi 4B if you install the WiringPi 2.52 update after doing the usual WiringPi installation using apt-get.
Seamus
  • 23,558
  • 83
