I am trying to get the MAX30102 heart sensor to run and have recompiled the kernel with the necessary module. I have loaded the follwing modules to be sure
i2c_dev
i2c-bmc2708
i2c-bmc2835
industrialio
max30102
I can verify this with lsmod
Module                  Size  Used by
max30102               16384  0
kfifo_buf              16384  1 max30102
regmap_i2c             16384  1 max30102
industrialio           73728  2 max30102,kfifo_buf
i2c_dev                20480  0
I have now found this device tree documentation and have tried adding
dtparam=interrupts=4,compatible=maxim,max30102,reg=0x57
to my /boot/config.txt as they are mentioned under the section "required" in the documentation. I just need to pass my interrupt pin which is connected to GPIO 4. But when I look under
$ for file in /sys/bus/i2c/devices/i2c-1/of_node/*; do ( echo $file; cat $file; echo "\n" )  ; done
/sys/bus/i2c/devices/i2c-1/of_node/#address-cells
/sys/bus/i2c/devices/i2c-1/of_node/clock-frequency ��
/sys/bus/i2c/devices/i2c-1/of_node/clocks
/sys/bus/i2c/devices/i2c-1/of_node/compatible brcm,bcm2711-i2cbrcm,bcm2835-i2c
/sys/bus/i2c/devices/i2c-1/of_node/interrupts u
/sys/bus/i2c/devices/i2c-1/of_node/name i2c
/sys/bus/i2c/devices/i2c-1/of_node/phandle 5
/sys/bus/i2c/devices/i2c-1/of_node/pinctrl-0
/sys/bus/i2c/devices/i2c-1/of_node/pinctrl-names default
/sys/bus/i2c/devices/i2c-1/of_node/reg ~�@
/sys/bus/i2c/devices/i2c-1/of_node/#size-cells
/sys/bus/i2c/devices/i2c-1/of_node/status okay
I still get the same values in the device tree. They are either empty or wrong.
neolith
  • 147
After a lot of research I found out that you have to create a device tree overlays for the driver module
// Overlay for max30102 heart rate sensor
/dts-v1/; /plugin/;
/ { compatible = "brcm,bcm2835";
fragment@0 {
    target = <&i2c_arm>;
    __overlay__ {
        #address-cells = <1>;
        #size-cells = <0>;
        max30102: heart-rate@57 {
            compatible = "maxim,max30102";
            reg = <0x57>;
            maxim,red-led-current-microamp = <7000>;
            maxim,ir-led-current-microamp  = <7000>;
            interrupt-parent  = <&gpio>;
            interrupts = <4 2>;
__overrides__ {
    int_pin = <&max30102>, "interrupts:0";
You can then configure the overlay in /boot/config.txt like this
# The default interrupt GPIO is still 4
dtoverlay=max30102
# Or to specify a different interrupt GPIO, e.g. 18
dtoverlay=max30102,int_pin=18
neolith
  • 147
