TL;DR When using ffmpeg and the h264_v4l2m2m hardware-accelerated codec, how do I set the encoder options such as the bitrate and key frame interval?
Details
I am using these commands to capture raw video from the Pi camera, draw the time and the Pi's temperature on the video, encode it to H264 with the hardware encoder, then stream it over the network:
v4l2-ctl -v width=1280,height=972,pixelformat=YU12
while true; do echo "PICAM02 $[`cat /sys/class/thermal/thermal_zone0/temp` / 1000]?C" > /tmp/msg; sleep 1; done &
ffmpeg -f rawvideo -pix_fmt yuv420p -video_size 1280x972 -use_wallclock_as_timestamps 1
-i /dev/video0 -vf 'pad=h=(in_h+40),
drawtext=x=(w-tw-8):y=(h-32):fontcolor=white:fontsize=30:text=%{localtime},
drawtext=x=8:y=(h-32):fontcolor=white:fontsize=30:textfile=/tmp/msg:reload=1'
-vsync 1 -r 30 -c:v h264_v4l2m2m -an -f rtp_mpegts "udp://224.0.1.2:5004"
It works, however when I use this command to view it, it only works if I start the viewer before streaming:
ffplay -sync ext -an -fast -framedrop -probesize 32 -window_title picam02 udp://224.0.1.2:5004
If the video is already streaming when I launch ffplay, I get a bunch of errors saying non-existing PPS 0 referenced. Apparently this error is because no keyframe has yet been received, and at least one key frame must be received before ffplay is able to start showing the video (because these frames include important things like the resolution of the video).
I therefore need to tell the hardware encoder to insert keyframes every few seconds, instead of the default which apparently only inserts one keyframe at the very start of the video.
How should I modify the above series of commands in order to configure the keyframe interval, and while I'm there, also the H264 bitrate and/or quality settings?
