I'm trying to follow through Ingo's guide here(Configuring Raspberry pi as Router, WiFi and Ethernet Bridge. One way or the other I can't seem to get it working though. I'm on Raspbian Buster. I'm using a pi 3B v2, with a working usb network adapter. After my first failure, I flashed a new microSD card and then (tried) followed the various posts:
  • Use systemd-networkd for general networking here
  • Next: Setting up a Raspberry Pi as an access point - the easy way here. Creating the exact same four interface configuration files (02-br0.netdev / 08-wlan0.network / 12-br0_add-eth0.network / 16-br0_up.network), modified the wpa_supplicant@wlan0.service according the example. Up to the point where the guide says to reboot and check if the bridge works.
I have the pi connected to a monitor + keyboard. The first thing I do after rebooting is run ifconfig to check network adapters and status. This then shows only the lo with 127.0.0.1
I am at a loss on how to proceed. Any help or tip will be hugely appreciated!
FYI My internet provider hands out a range of 192.168.0.1/24 Purpose would be to connect eth1 to the internet switch. Wlan0 + eth0 would then be bridged and serve out DHCP
ipanini
