I suddenly couldn't wget a file after having gotten one 5 mins before.
I can no longer "ping google.com"
I can "ping 1.1.1.1"
/etc/resolv.conf:
#Generated by resolvconf
nameserver 1.1.1.1
nameserver 8.8.8.8
ifconfig for eth0(which is what I am using):
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 192.168.0.142  netmask 255.255.255.0  broadcast 192.168.0.255
    inet6 fe80::15b5:7a2e:8121:e45e  prefixlen 64  scopeid 0x20<link>
    ether dc:a6:32:43:a3:9b  txqueuelen 1000  (Ethernet)
    RX packets 11804  bytes 1565414 (1.4 MiB)
    TX packets 2577  bytes 301865 (294.7 KiB)
Output from route -n
Kernel IP routing table
 Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
 0.0.0.0         192.168.0.1     0.0.0.0         UG    202    0        0 eth0
 10.6.0.0        0.0.0.0         255.255.255.0   U     0      0        0 wg0
 192.168.0.0     0.0.0.0         255.255.255.0   U     202    0        0 eth0
Result from traceroute 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 60 byte packets
1  192.168.0.1 (192.168.0.1)  0.420 ms  0.398 ms  0.369 ms
2  10.200.211.1 (10.200.211.1)  2.708 ms  2.540 ms  2.494 ms
3  192.38.10.89 (192.38.10.89)  21.809 ms  21.779 ms  21.640 ms
4  130.225.245.13 (130.225.245.13)  8.338 ms  8.277 ms  11.434 ms
5  109.105.102.160 (109.105.102.160)  9.342 ms  9.145 ms  9.119 ms
6  109.105.97.117 (109.105.97.117)  8.959 ms  9.468 ms  9.970 ms
7  212.237.193.246 (212.237.193.246)  10.997 ms 212.237.192.246 (212.237.192.246)  11.016 ms 10.305 ms
8  1.1.1.1 (1.1.1.1)  10.643 ms  10.550 ms  9.560 ms
The error was at least partially due to a wrong configuration file. The file: /etc/nsswitch.conf mdns4 needed to be changed to dns
