How can I set up a static IP on my Arch Linux installation so I can easily SSH in?
I followed this thread, but I could not get the static IP I set to work! Here's my /etc/netctl/eth0 file:
Description='A simple ethernet connection using a static IP'
Interface=eth0
Connection=ethernet
IP=static
Address=('192.168.1.5/24')
Can anyone see what my problem is and/or point/give me to a good tutorial on how to set this up?
DHCP isn't a huge problem, just a little slower, because I have to look up the IP via the router.
EDIT: Trying @syb0rg's solution:
I worked through the solution up to the netctl start eth0 part, and then it threw an error:
$ sudo netctl start eth0
Job for netctl@eth0.service failed. See 'systemctl status netctl@eth0.service' and 'journalctl -xn' for details.
$ systemctl status netctl@eth0.service
netctl@eth0.service - Networking for netctl profile eth0
   Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static)
   Active: failed (Result: exit-code) since Wed 1969-12-31 19:12:12 EST; 21s ago
     Docs: man:netctl.profile(5)
  Process: 316 ExecStart=/usr/lib/network/network start %I (code=exited, status=1/FAILURE)
 Main PID: 316 (code=exited, status=1/FAILURE)
journalctl -xn
-- Logs begin at Wed 1969-12-31 19:00:32 EST, end at Wed 1969-12-31 19:10:43 EST
Dec 31 19:08:49 ArchPiServer systemd[294]: Stopped target Sound Card.
-- Subject: Unit UNIT has finished shutting down
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Documentation: http://www.freedesktop.org/wiki/Software/systemd/catalog/9d1aa
-- Unit UNIT has finished shutting down.
Dec 31 19:08:49 ArchPiServer systemd[294]: Starting Default.
-- Subject: Unit UNIT has begun with start-up
-- Unit UNIT has begun starting up.
Dec 31 19:08:49 ArchPiServer systemd[294]: Reached target Default.
-- Subject: Unit UNIT has finished start-up
-- Unit UNIT has finished starting up.
-- The start-up result is done.
Dec 31 19:08:49 ArchPiServer systemd[294]: Startup finished in 830ms.
-- Subject: System start-up is now complete
-- All system services necessary queued for starting at boot have been
-- successfully started. Note that this does not mean that the machine is
-- now idle as services might still be busy with completing start-up.
-- Kernel start-up required KERNEL_USEC microseconds.
-- Initial RAM disk start-up required INITRD_USEC microseconds.
-- Userspace start-up required 830163 microseconds.
Dec 31 19:10:43 ArchPiServer sudo[301]: pam_unix(sudo:account): account server-g
What gives?
RPiAwesomeness
  • 3,021
  • 52
Change directories to access the network settings:
# cd /etc/netctl
# cp examples/ethernet-static ./eth0
We need to edit the configuration file, etch0, and add in the settings we need. Before you proceed, you will need the following:
  • Static IP address – I’m using 192.168.1.36. The netmask I’m using is 255.255.255.0 which is defined as "/24" or the first 24 bits.
  • An Interface name – I’m using eth0.
  • A default gateway – I use 192.168.1.1.
  • Some DNS names servers – I’m using 8.8.8.8 and 194.168.4.100 and 194.168.8.100 – which are Google and Virgin Media’s DNS servers. You should use the ones you have been told to use by your own ISP.
When you have finished editing the file, it should look like the following, using the settings above:
Description='Anything you like'
Interface=eth0
Connection=ethernet
IP=static
Address=('192.168.1.36/24')
gateway=('192.168.1.1')
DNS=('8.8.8.8' '194.168.4.100' '194.168.8.100')
Save the file and exit the editor. Try starting the network:
# netctl start eth0
Note: On my system, that always returns an error, but the networking actually begins working.
After this, I can ping 8.8.8.8 and also ping google.com and in both cases, get a correct response.
If your network starts ok, without error, and works, then you can configure it to always start on boot by running the following command:
# netctl enable eth0
If you ever decide to disable it again, it’s equally as simple:
# netctl disable eth0
syb0rg
  • 8,178
  • 38
You would be better to set your router to serve a static IP to the Pi. This way you can easily use the Pi on other networks, and avoid problems with duplicate IP
You have to add
AutoWired=yes
to your static config in order to get it to work.
Here's a tutorial: http://blog.pixxis.be/post/77298179924/setting-up-a-static-ip-on-arch-linux
All of these solutions didn't work for me. I fixed it by doing this:
sudo vim /etc/systemd/network/eth0.network
remove the line that says
DHCP=yes
then, make sure your [Network] part looks like this:
[Network]
Address=192.168.1.40/24
Gateway=192.168.1.1
Of course, replace the values of Address and Gateway by the values you desire. Reboot your device.
Exeleration-G
  • 303
