22
I have a couple of files on the Raspberry Pi's file system that I need to get. I have the Pi's SD card and an SD card reader.
How can I read files off my Raspberry Pi's SD Card on a Windows PC?
Stevoisiak
  • 321
Dvidunis
  • 321
8 Answers8
Try Ext2Read or Paragon ExtFS for Windows.
scruss
  • 9,117
  • 25
  • 36
Just to note that the paragon tool appears to work. It allows ext4 or whatever partitions to be seen on Window explorer. And edited.
We used Notepad++ as an editor to avoid upsetting the CRLF double linefeed issue.
Rob
  • 81
Easiest way would be to boot a PC into linux and mount the SD card. Any 'live' CD or USB stick disto would do. As you are used to raspian a Debian based distro like Ubuntu or Mint might be best. If you download unetbootin it will give you a menu of distros, download your choice, write it to a USB stick and make the stick bootable. Then just reboot and you have a machine that can read your SD card. Copy the stuff onto your hard disc, or another USB stick (or even the boot one - it won't be full and will be FAT32). Reboot back into Windows and you are done.
Julian
  • 219
I use Diskinternals Linux Reader.
Benjamin Ashbaugh
  • 1,087
If you have an USB Key, you could boot your Pi and simply copy the files onto the key. Another solution would be to install a Linux Live System onto the stick, boot your PC from there and copy the files from the SD to your hard drive. If you don't have an USB key, you can boot your Pi, connect from your PC via SSH and copy the files via scp. Or via FTP, SMB ...
Oli
  • 111
If you can ssh into your Pi, then you can also sftp into it. [sftp username@IPaddress] Navigate to the directory using change directory. [cd] If along the way you need to look at the directory contents, you can list them. [dir] Then use the get command to retrieve the file. [get filename] If you know the exact path, you can get it without the navigation. [get /path/to/filename]
dacracot
  • 191
U can access only via Linux machine... u would see 3 partition... one will be "root" partition and that would corresponds to OS file system.
Apurv
Try using FileZilla and connect to the host with port 22 (ssh default) and don't forget the account credentials because you'll need them, Find the file, then drag+drop anywhere, May take a bit to download depending on the connection
Joyesh
