I have a Pi 3 Model B Rev 1.2 which has been running fine for 2 months. It was accidentally knocked off its shelf yesterday (about 1foot drop) It booted back up fine, but now it only stays on for 20 minutes before abruptly disconnecting. The red power light is on steady, but ethernet is off, and it seems all other power is off.
Is a 1 foot drop (plastic case) enough to damage the hardware? Is there a process I can implement to help me figure out if this is a hardware error within the 20 minutes it stays accessible?
I have Debian 10 installed on the system.
Ken Ingram
  • 261
You stated in a comment that you have the same problem with the same SD Card in other hardware. So it is very likely that the SD Card is broken. Just use a new SD Card and reflash it with the operating system. You should use a new installation and not a clone from the old SD Card because it can not be sure that programs have not become defective.
Ingo
  • 42,961
  • 207
Springboarding off of @Ingo's answer, you might also try fscking your SD card to potentially discover and correct any errors in the filesystems on your SD card (no - fsck won't correct hardware errors).
If you want to try this, there's another answer here with a procedure for running fsck (actually both e2fsck and fsck.vfat) on your card.
Seamus
  • 23,558
  • 83
